Way to hack a solution, Get a 1W load for the 3.3V rail, grab the feedback 3.3V wire from the ATX24 plug, and divide it down with a pot (start at a ratio very close to 1, then slowly edge away with a voltmeter on the 12V rail, this will raise the output voltage as the regulation % follows from the 3.3V rail,
also get yourself a big stud diode, if the atx looses power and there is still power on its outputs, weird things can happen,
