Author Topic: PFC Regulator using basic components  (Read 2057 times)
Offline akhiTopic starter
« on: August 07, 2023, 02:30:01 pm »
Dear Community,
I would like to design my own PFC Controller using basic components (OPAMP, Comparators, Transistors...). Is it a hard task? Is there any guideline books or application note or maybe better a reference design. I want to replace NCP1654 on my board.
Online jbb
Re: PFC Regulator using basic components
« Reply #1 on: August 08, 2023, 04:09:24 am »
You could in principle, but it would be a lot of work.
If you look at the functional block diagram of the NCP1654, it shows some special analog processing around the current control loop: a multiplier for scaling the current sense target into a (rectified) sine wave and a divider for scaling the DC link voltage control signal into a current demand. Those functions can be done with basic parts (eg exponential and logarithmic converters using BJTs) but it would turn into a LOT of parts.
Could be an interesting ‘learn about analog’ project. I’m practice I think you’d have a lot of trouble getting anything to operate nicely. For example, noise from the power switching could couple into the analog electronics and make the whole thing go haywire.
Offline Konkedout
« Reply #2 on: August 08, 2023, 04:43:50 am »
There are a lot of variables.  Perhaps the most basic type of PFC boost stage runs in "critical conduction mode."  I just googled that and came up with a bunch of "hits" from IC manufacturers describing how it works.  One disadvantage of this is a switching frequency which varies down to low (such as maybe 25 KHz) so greater filtering is required.  In general there is a lot to go wrong with a PFC pre-regulator, so it is wise to read up as much as possible before diving in.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 08, 2023, 05:18:29 am »
Not terribly difficult in BCM, though I make no claims that this circuit is anywhere near production-ready. ;D
https://www.eevblog.com/forum/projects/power-factor-correction-discrete-control-circuit-(for-bcm)/
Seven Transistor Labs, LLC
The following users thanked this post: akhi
Offline Terry Bites
« Reply #4 on: August 08, 2023, 07:44:49 am »
Welcome to the reinventing the wheel forum.
You can I suppose you might build one but you need to think about the risks.
The pfc sits just down stream from the mains rectifier so it needs to be constructed to a very high standard even for a lab demo.
Working on it while powered up could be fatal for you and your lab equipment.
If you live alone in your own detached house, then go ahead.
I wouldn't let a home made pfc out of my sight and I'm a paid up pyromaniac!
The following users thanked this post: Roehrenonkel, akhi
Online NiHaoMike
    • Facebook Page
« Reply #6 on: August 08, 2023, 01:33:47 pm »
For learning about it, using low voltage AC from a transformer would make it a lot safer. You can even go a step further and make your own grid tie inverter, which can be thought of as a PFC with the current direction in reverse.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
