Author Topic: Photodiode circuit  (Read 2613 times)
Offline aiq25Topic starter
Photodiode circuit
« on: May 15, 2017, 01:09:48 pm »
Hello. I'm having a hard time understanding the attached photodiode circuit.
I can understand the circuit without R2: Vout = R1•Ipd and the photodiode is reverted bias. But I'm not sure what Vout would be with R2. It's creating a voltage divider but what's the output equation?
Any feedback would be appreciated. Thanks.
Offline Zero999
  • 0999
Re: Photodiode circuit
« Reply #1 on: May 15, 2017, 02:02:39 pm »
Hint: the output impedance of the voltage divider is equal to both the resistors in the divider connected in parallel.
« Reply #2 on: May 15, 2017, 02:16:49 pm »
The equation should be: R2/(R1 + R2). But is voltage just the output impedance•Ipd? I guess I'm confused as to how the photodiode current generated and the current from VCC affects the output voltage.
Would photodiode current would generate a voltage across just across R2? Since the photodiode is in reverse bias, would R1 have an effect on about?
Offline Andy Watson
« Reply #3 on: May 15, 2017, 02:38:26 pm »
Look up Thevenin (and Norton).
Offline Zero999
  • 0999
« Reply #4 on: May 16, 2017, 03:26:09 pm »
Model the potential divider as an ideal voltage source, V = VCC*R2/(R1 + R2), with an output impedance of R1|R2 in series with the photodiode.
