Author Topic: Photodiode / Transimpedance Circuit simulation with QUCS  (Read 4862 times)
Offline BigmanTopic starter
« on: March 15, 2015, 01:28:21 pm »
Hi everybody,
QUCS offers a photodiode as a component. But when I run a simulation, the output (see attached screenshot) is not what I expected.
The voltage at the summing junction is constantly -0.742 Volts. Since the non-inverting input is referenced to 0V, I expected the voltage at the summing junction should be forced down by the output-voltage also to 0V.
What am I missing here? Thanks in advance for every hint & tip!
Offline ignamv
Re: Photodiode / Transimpedance Circuit simulation with QUCS
« Reply #1 on: March 15, 2015, 01:33:13 pm »
You need more current flowing into the - node, to make up for the photodiode's current. Either decrease the feedback resistor, or increase supply voltage (your output is saturating).
Offline w2aew
    • My YouTube Channel
« Reply #2 on: March 15, 2015, 01:42:32 pm »
The input common mode range of this op amp does not include the negative supply rail.
FAE for Tektronix
« Reply #3 on: March 15, 2015, 01:56:01 pm »
As a newbie in electronics, pls. allow me to ask if you could explain this a bit more. I can only assume what you mean, and now something like this is keeping my brain busy: the photodiode is creating at the summing junction a negative potential (relating to GND). But since Vee is also on GND, the OpAmp cannot handle a potential more negative than at Vee ... is this what you mean?
Offline ignamv
« Reply #4 on: March 15, 2015, 05:25:08 pm »
You have to keep the inputs away from the rails.
Also consider putting a small cap across the feedback resistor to reduce ringing.
Online tggzzz
« Reply #5 on: March 15, 2015, 05:52:13 pm »
See the top half dozen links http://lmgtfy.com/?q=input+common+mode+range+of+this+op+amp
They have taken the trouble to give you a coherent answer.
