EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
pic port amplify
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: pic port amplify (Read 3528 times)
gatoulisss
Contributor
pic port amplify
on:
February 05, 2015, 01:36:46 pm »
hello guys!!
i have a question.
im using pic 16f88 connected to some sensors and a buzzer its like an alarm, my question is can i amplify the output of the pin witch is connected to the buzzer so i can have much louder sound? (the sound driver is the pic so the buzzer is not making any sound if i just connect it to a battey) for example the port output is +5v can i make it +9 and how?
thank you very much!
Logged
johm
Contributor
Country:
Really fond of Sines & Silicon.
Re: pic port amplify
Reply #1 on:
February 05, 2015, 02:29:47 pm »
One of your solutions is using an off the shelf NPN transistor (2n2222, 2n3904, BC548, etc.) wired like this:
An NPN Transistor behaves like a current switch / current amplifier. The higher current any output pin of the PIC16F88 can sink/source is 25mA, as in pg. 161
http://ww1.microchip.com/downloads/en/DeviceDoc/30487D.pdf
so this will allow a higher current to flow from the collector to the emitter of the transistor resulting in louder sound.
In case you don't understand something, feel free to ask.
Regards,
Johm
Logged
Assembly is the high level programming for an ASIC design engineer (with no VHDL/Verilog).
gatoulisss
Contributor
Reply #2 on:
February 05, 2015, 02:50:42 pm »
i tried with bc547 transistor and it works on some buzzers but in this type is not
http://www.ebay.com/itm/231141835644?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
any idea?
and is there any way to amplify the buzzer using a transformer? and how i can make the connections?
Last Edit: February 05, 2015, 03:10:39 pm by gatoulisss
Logged
johm
Contributor
Country:
Reply #3 on:
February 05, 2015, 03:29:56 pm »
Using a transformer is an overkill, what's more, you'll have to add a DC voltage for the buzzer to work. Have you got the datasheet for this particular buzzer? Take a look at its impedance and operating voltage.
Logged
gatoulisss
Contributor
Reply #4 on:
February 05, 2015, 04:17:20 pm »
i had the buzzer of the foto and is loud as i want to be and it use an transformer... so i think that using transformer in the ones i got would give me the loudness i want. so how i can make this?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
pic port amplify
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
