Author Topic: Picoammeter Design  (Read 265376 times)
Offline magic
Re: Picoammeter Design
« Reply #325 on: July 02, 2023, 10:09:10 am »
So far I've made a sim with the T in the FB..
Aprox 10pA/V output..
600μV/rtHz output referred noise from Johnson alone, 5mVpp or more in DC-1Hz bandwidth.
Does SPICE agree?
SNR is maximized by putting all your high resistors in series for feedback, until you have a problem with input current being too large for the output voltage swing of the chip. On second thought though, the difference between 800MΩ and 500MΩ will not be huge. But with several mV output noise there is perhaps no point having so much gain...
Note that your circuit is almost equivalent to a simple TIA with 500MΩ feedback followed by a 200x gain stage. (The only improvement is, noise and offset of one opamp instead of two).
I guess the 1G in my case beeing low is a blessing in disguise, having such a convenient way trim the output.
Compare that to the hassle of trimming a high one down with an excact parallel resistor  >:D
I would divide the output of the TIA down by a few % or whatever it takes. But then it may need to be buffered somehow from external loads.
« Last Edit: July 02, 2023, 11:13:46 am by magic »
Offline iMo
  • Country: li
« Reply #326 on: July 02, 2023, 10:24:10 am »
With the 80% divider for 800Meg FB resistor.
PS: Could it be in my Unknown probe the 39k resistor was actually a part of such an divider, such they were changing the probe gain from outside??
« Last Edit: July 02, 2023, 12:31:34 pm by iMo »
Offline ch_scr
« Reply #327 on: July 03, 2023, 07:49:07 am »
Some sort of addendum, here's my schematic for a "TIA with discrete dual-P-FET input stage". As we've learned above, a bit of divider action before the feedback would be advisable to be able to trim the output. Had it running half the day on sunday and didn't observe any noticeable drift on the offset.
Offline magic
« Reply #328 on: July 03, 2023, 08:13:28 am »
That's the high effort way. The lazy way is to plug them as source followers in front of a bipolar opamp, like in iMo's mystery probe.
Is there any reason for this gain stage? OP07 noise shouldn't be a problem (the FETs are probably worse) and its DC voltage gain is good enough too, I think?
edit
As before, I wonder if drain voltage has any influence on gate leakage current; perhaps there is a particular point where Ig drops to zero?
And regarding offset, there is a difference between offset voltage of the input stage and "offset" due to input leakage current. The latter can be hidden by temporarily shorting the feedback resistor. I think I would trim for zero voltage offset (with shorted feedback) in order to minimize leakage across insulation of the Hi-Z circuitry, input connector, any external cables, etc.
« Last Edit: July 03, 2023, 08:20:43 am by magic »
Offline ch_scr
« Reply #329 on: July 03, 2023, 11:02:43 am »
edit
I've never implemented a discrete input stage before, so I worked from the LIS LS844 Appnote. Which made it sound like there is no downside (aside from low gain stability) to the "gain arrangement" compared to the "source follower".
I'll try the "shorted feedback" zero - I suspect it might be almost the same as now, with my ill guided "shorted input, measure -in to +in" zero attempt.
Will experiment with the effect of negative supply (and thus, drain voltage) on the leakage. I could also try to make the bulk/substrate substantially more positive than the source voltage?
I've taken it apart for now anyway; to add the "3x 100pF NP0 in series" 33pF feedback capacitor, an divider to get the gain up to 1mV/pA, mechanical improvement, more thorough cleaning (soapy water, DI water bath before IPA hose down, instead of only the latter) and measurement of the 1G resistor.
Offline ch_scr
« Reply #330 on: July 03, 2023, 05:07:56 pm »
Similar experience to mine. I tested several specimens of different values, it was a few years ago, but I'm fairly sure all were found to be 5~10% off, always on the low side.
What I haven't done was to re-test at 10V to check voltage coefficient.
Point 9 of the datasheet does specify "change in resistance as a function of change in voltage, no more than ±5%". So maybe it's partly responsible?
The 1G I had used in circuit measures:
10V - 891M
100V - 857M
The other 1G specimen:
10V - 921M
100V - 911M
I'll try to use the latter now.
Edit: offset was found to be 150uV with the feedback shorted, so the "misguided" method worked fine as well, just higher effort.
Edit #2: the circuit is quite sensitive to the negative supply (and thus, drain voltage on the dual fet).
Not sure to measure the input leakage with open input or shunted over e.g. 120Meg? Did both:
Measured output:
state:   open        120Meg shunted
V-
-10V     600uV       8mV
-12V     0V            2mV
-14V    -700uV     -4mV
« Last Edit: July 04, 2023, 04:36:51 pm by ch_scr »
Offline MegaVolt
  • Country: by
« Reply #331 on: July 04, 2023, 09:15:39 am »
Analog Devices provides a very handy tool for estimating bandwidth and noise for different amplifiers. Including for transimpedance.
Graphs show all components of noise including each resistor, input currents and op amp noise, etc...
https://beta-tools.analog.com/noise/
Offline ch_scr
« Reply #332 on: July 04, 2023, 10:35:35 am »
They calculate 65uV RMS for a 1G / 33pF TIA. I've measured about 90uV RMS for my build, doesn't seem too shabby?
Offline MegaVolt
  • Country: by
« Reply #333 on: July 04, 2023, 10:43:39 am »
The output noise of the TIA can be affected by the input capacitance of the source. You can put a photodiode at the input and set its input capacitance and observe the increase in noise.
Offline bsw_m
  • Country: by
« Reply #334 on: September 08, 2023, 10:21:19 am »
Current measurement ±1fA. Current source: NK4-1.
As a meter: ADA4530-1 integrating current-voltage converter
A bit of detail, a 10pF air capacitor is used as the feedback capacitor.
There is a differentiator at the output of the integrator. The output of the differentiator was measured with a voltmeter. No filtering/averaging was used.
The following users thanked this post: doktor pyta
Offline bsw_m
  • Country: by
« Reply #335 on: September 08, 2023, 11:17:33 am »
Very simplified, the schematic of this I-V converter looks as shown in the attachment.
« Last Edit: September 08, 2023, 11:29:45 am by bsw_m »
Offline dobsonr741
« Reply #336 on: November 18, 2023, 03:05:03 pm »
About to build the classic one with LMC662 and 1G resistor, have 5x SO8 on cut tape. Should I bother picking the lowest input current one? In more details:
  • What will be the symptoms of choosing a higher input current vs. lower in practical terms, how’s it going to limit my ability to measure leakage currents in the 10pA range?
  • Given they are all from the same batch, should I expect huge variations in input current?
  • Should i expect major input current variances between the two opamp on the same die, or not?
Offline magic
« Reply #337 on: November 18, 2023, 03:44:43 pm »
I tried two chips and they were <0.01pA. I don't recall anyone here reporting a specimen with abnormally high leakage.
To measure yours:
- short across 1GΩ and measure offset voltage of the opamp
- remove the short, subtract previously measured offset voltage from the new output, divide by 1GΩ to calculate input bias current
The following users thanked this post: dobsonr741
Offline dobsonr741
« Reply #338 on: November 18, 2023, 07:40:25 pm »
Wow, can not measure the input bias current. So low. Nulled out to <1uV offset when sorted. Short removed from 1G and it still stays within +/-2uV noise. Checked the 1G - it's really 1G. Air movements with open lid takes it 200uV away. Happy with the build.
Some of the measurements I did with it:
BAV199W leakage @5V: 100fA
CPC1025  leakage @5V: 700fA
« Last Edit: November 19, 2023, 01:07:58 am by dobsonr741 »
Offline zrq
« Reply #339 on: July 27, 2024, 10:05:18 pm »
It seems in the recent revision of the datasheet, it clearly says OPA928 can operate at Vs=36 V. To me this imply it's a very good drop-in replacement for AD549 in legacy designs. I would like to try upgrading my Keithley 238's two AD549s in the guard driver and voltage sense buffer with OPA928, powered by +-15V. This should basically eliminate the offset current.
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #340 on: July 27, 2024, 10:40:13 pm »
From the datasheet on OPA928 you need to pay attention to the common mode voltages as the OPA928 has a different CM range to the AD549, with +/-18V supply it doesn't like to go positive over about 3-5V from the supply midpoint, with potentially a substantial increase in the input current at higher CM voltages.
Cheers
Alex
The following users thanked this post: zrq
Offline zrq
« Reply #341 on: July 28, 2024, 09:18:36 am »
Oh nice catch! Thanks!. It's mentioned in the section 6.3.6 of the OPA928 datasheet the recommended Vcm to be less than (V–) + 20V.
Thus it's unsuitable for use in the Keithley 23x for the current feedback amplifier U3, which is powered by +-15VF and may take up to +-10V of common mode voltage at full scale. However I think it should work for U2, which is powered by the power supply bootstrapped by the output voltage +-15VFB, and should nominally take very little common mode voltage.
Offline pinout666
« Reply #342 on: January 06, 2025, 10:25:44 pm »
Hello, here a low cost design 100fa
https://www.elektormagazine.com/articles/circuit-a-diy-picoammeter-design
and a 1fA design
https://www.analog.com/en/resources/technical-articles/op-amp-combines-femtoamp-bias-current-with-4ghz-gain-bandwidth-product.html
my question it is possible to make a mix with ltc6268 only +1 bf245 +1adc ,(edit with big  resistor it's ok, but i eject the lt1055 ^^), for low cost but "powerfull" ?
(the dream,with single supply )
« Last Edit: January 07, 2025, 03:53:55 am by pinout666 »
Offline David Hess
  • DavidH
« Reply #343 on: January 07, 2025, 01:32:33 am »
A picoammeter can be made with matched transistors instead of a high value resistor.  Burr-Brown showed this idea with transistors replacing the resistors in an inverting amplifier, but here PMI shows the same idea used as a current multiplier.
Offline pinout666
« Reply #344 on: January 07, 2025, 03:40:03 am »
Thanks for your document but the price for the "precision" transistors is to big :/
(but maybe https://www.mouser.co.uk/c/?marcom=116270663
https://www.diyaudio.com/community/threads/mat02-03-elektor-preamp-schematic.41993/page-6
, and if possible the range for 1fA maybe 10fA (in fact maybe the opa928 is a possible option , but if
is possible to play with  the 1fa range it's more interesting )
(and on mouser, smd resistor with big value is findable , with low price)
« Last Edit: January 07, 2025, 04:35:49 am by pinout666 »
Offline David Hess
  • DavidH
« Reply #345 on: January 07, 2025, 08:00:40 am »
It is too bad that pricing and availability are not better.  Rochester has the MAT02 in the leaded package for about $10.  Digikey and Rochester have the Linear Systems dual transistors for about $10 also but being super beta transistor, the circuit would require some modifications.
I wonder how well a pair of matched and thermally coupled BC546s would work.
« Last Edit: January 07, 2025, 08:29:49 am by David Hess »
Offline Kleinstein
« Reply #346 on: January 07, 2025, 10:28:26 am »
Using a transistor instead of the high value resistor is not really helping with the noise. It can would for the somewhat higher ranges like 100 pA with limted resolution.
Especially for the really low current range (e.g. < 10 pA) the alternative to a very large resistor is using an integrator. So measure the current as I = C*dU/dt for the integrator. This  however needs a way for a periodic reset, as the integrator will eventually saturate. With low current that can still be an hour between resets and a special low leakage mechanical relay is possible.
A possiblity here is to use a photodiode and LED to provide compensating current, up to the point of using it for a kind integrating ADC directly.
Offline Gyro
« Reply #347 on: January 07, 2025, 12:59:02 pm »
Isn't the diode / diode connected jfet / transistor there to provide a wide range logarithmic scale?
I would avoid using the OPA928 opamp. It is a 500MHz part that could cause layout dependent instability. Yes, it has a headline typical room temperature input current of 3fA but so does the slower LMC662 which is used in many implementations in this thread. In both cases, it is necessary to select samples that meet this low current and probably low offset too (although for the LMC662 at least, it seems that most parts do).
Best Regards, Chris
Offline Kleinstein
« Reply #348 on: January 07, 2025, 02:36:24 pm »
The diode / transistor gives an intermediate logarithmic scale. In the example circuit the 2nd transistor converts back to a linear scale. The problem is that his method is relatively noisy and prone to drift - maybe OK for a linear meter and not very low currents. For this performance range one could get away with a more moderate resistor of maybe 100 M. What one can save on are switches in the leakage critical part.
Offline iMo
  • Country: li
« Reply #349 on: January 07, 2025, 02:57:48 pm »
Does the noise with the above schematics is a relevant obstacle when targeting, say, 1-5% "precision" (pretty good for that type of measurements, imho)??
I doubt somebody here wants to start binning his/her jfets based on three digits gate current precision..
Knowing the sub 100pA currents with 10% precision would make me quite happy..
« Last Edit: January 07, 2025, 03:09:33 pm by iMo »
