Author Topic: Piezoelectric Force Sensor Testing  (Read 1168 times)
Offline gregoliveTopic starter
« on: March 07, 2018, 05:51:47 pm »
Hello,
I am working on a project where I am using piezoelectric force sensors and logging the data on a Teensy 3.6 micro-controller. I am currently testing the sensors at a drop tower and have a question about the results. When testing at lower loads (~700N) the force sensor performs as expected with a spike upwards at impact (see attached photo), however at higher loads (~1800N) the spike goes slightly up, but mostly down at impact. Has anyone experienced this before? Thanks for the help!
Offline rhb
Re: Piezoelectric Force Sensor Testing
« Reply #1 on: March 08, 2018, 02:52:49 pm »
Post some photographs of the setup for both cases.  A wild guess is that the larger load is deflecting the sensor support.  But that's all it is, a wild guess.
Offline Ian.M
« Reply #2 on: March 08, 2018, 04:22:52 pm »
Your Teensy data logger doesn't have a high enough sample rate to see what's actually happening.  Can you capture the spikes at a much faster timebase using a DSO so we can see more detail?
Also, in addition to the photos rhb requested, the schematic of the signal conditioning circuit and datasheet of the sensor would be helpful.
