Looking for some input on how you would place a fan in this scenario.
in-wall plastic leviton media box, 14x14 inch. In it will be a optiplex micro pc that has intel i5 and my apps will run the cpu heavy. In the box will also be the pc 90w brick psu. Media box has cooling slots/holes running down middle of the cover.
I have a 3" usb-a cooling fan that I will mount in upper right corner of the cover. PC is located bottom left. The micro will sit on it's side, so it's own cooling exit holes are upper right on this pc, it too has a internal cooling fan.
The box itself is mostly sealed off (holes and stuff taped over). One 1" knockout up top that brings in a few low voltage wires, and one receptacle box on the lower.
Would you place fan to pull out hot air (neg air pressure in box), or push in cool air (pos air pressure in box)?
