Author Topic: power connection  (Read 830 times)
Offline starTopic starter
power connection
« on: August 27, 2026, 07:32:41 am »
Need some help
I have a old slushie unit... Taylor magnablend SB25.
Its got a very strange power supply, I am trying to see if i can make up a power unit that will do the work
SUPPLY-POWER-IO 081217  1  103  RINSE STATION, I have the electrical schematics
I think I found one
but the connection looks odd? Pictures attached
https://leeselectronic.com/qc/product/17211-power-adapter-ac-ac-linear-24v-1a.html
can you advise.. i cant find a picture of this power supply on the net..... even odder.
Thanks
Offline Psi
Re: power connection
« Reply #1 on: August 27, 2026, 07:53:08 am »
Does that jack have threads on the inside, kinda looks like it might be threaded.
And the rubber o-ring makes me think it's waterproof. Which would make sense given application and explain being threaded to compress the o-ring.
Offline Terry Bites
« Reply #2 on: August 28, 2026, 03:01:23 pm »
« Reply #3 on: August 28, 2026, 06:42:39 pm »
Thanks for tehy feedback
yes, it does look like a odd connection.
Attached more pictures
I wonder if I can simply replace this connection with a plug in version, so that where I can use a normal step down 24VAC adpator of the shelf.
This power unit from the manufacturer is $512...thats just crazy.
Need some alternate options to rewire this
« Last Edit: August 28, 2026, 06:50:17 pm by star »
« Reply #4 on: August 28, 2026, 06:46:55 pm »
Thanks, you found the wierd connection!
Does that mean I can buy the male adpator and rewire it to this
and it should work?
Thanks again
Offline aeg
« Reply #5 on: August 28, 2026, 11:01:49 pm »
If you're in the US then why are you so obsessed with getting that power adapter from that Canadian supplier and paying an import tariff, it literally has the Jameco catalog number printed on it and Jameco sells it for half the price
Offline moffy
« Reply #6 on: August 28, 2026, 11:07:12 pm »
and it should work?
Thanks again
Based on the Specification plate in your first post it should be fine.
« Reply #7 on: September 01, 2026, 05:35:54 pm »
No obssed about the canadians!
never heard of Jameco till you mentioned it.
Will look there since its closer to me (big Bear)
Thanks
