Author Topic: Power correction application  (Read 2452 times)
Offline calexanianTopic starter
    • Alex-Tronix
« on: January 01, 2014, 05:14:08 am »
While working on something the other day I came up with an application that got me thinking. I have a DC permanent magnet motor that runs off of a car battery. Its actually a bilge pump in this application but that is not critical for this exercise. Ignoring varying load on the motor etc lets assume its speed is voltage Dependant. As my battery dies the speed of the motor will change as well, additionally I may want to run the motor at a lower voltage in a regulated fashion for a lower speed. As well as all this as the battery dies the voltage may fall below where I want it. This motor has a stall current of 10 amps, and therefore a startup current of 10 amps. I have designed buck converters, and I have designed boost converters. Has anybody ever encountered or designed one that will seamlessly do both and give a linear adjustable voltage range? My mind went to a boost converter, followed by a switching regulator. Yea that would work, but there has to be a more efficient way that two switching circuits in series. Any thoughts?
Charles Alexanian
Alex-Tronix Control Systems
Offline Rerouter
Re: Power correction application
« Reply #1 on: January 01, 2014, 08:36:54 am »
sepic converter?
Offline Kremmen
« Reply #2 on: January 01, 2014, 02:56:04 pm »
Sepic or buck-boost.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline nctnico
« Reply #3 on: January 01, 2014, 03:34:39 pm »
Just PWM it at 1kHz or so with a reasonable sized MOSFET. I wouldn't draw more current from a battery when it is empty. You'll wreck the battery. If you want to increase the voltage there is a nice picture of a motor drive in the Prius teardown report: http://www.osti.gov/bridge/purl.cover.jsp?purl=/890029-WIfqPO/
« Last Edit: January 01, 2014, 03:37:03 pm by nctnico »
    • Alex-Tronix
« Reply #4 on: January 01, 2014, 05:26:56 pm »
sepic converter?
There we go. Thanks.
Charles Alexanian
