Author Topic: Power supply for RD6006  (Read 3840 times)
Offline bikeseatTopic starter
« on: October 19, 2023, 06:22:27 am »
I've ordered an RD6006 and am wondering if I can (or even should) use a USB Type C PD power supply with it?
Adafruit has this device that I think would suffice:
https://www.adafruit.com/product/5807 (Adafruit USB Type C Power Delivery Dummy Breakout - I2C or Fixed - HUSB238)
I don't need super high current for my projects, so if anyone has other suggestions, I'd definitely appreciate hearing them.
Thanks for reading!
Offline wrickert
Re: Power supply for RD6006
« Reply #1 on: November 16, 2023, 04:33:01 pm »
Sure, why not.
Offline Jackster
    • PCBA.UK
« Reply #2 on: November 16, 2023, 10:40:59 pm »
Just get the 65V 400W power supply that is designed for it?
https://www.aliexpress.com/item/1005003036945650.html
They make for a nice little power supply.
Offline Partizans
« Reply #3 on: November 20, 2023, 08:16:22 am »
I'm curious, in the current model RD6006, for "curve display" are there Chinese characters on display right side (even in English language mode)?
Offline jdev99
« Reply #4 on: January 31, 2024, 01:48:41 pm »
Quote from: Partizans
Try updating the firmware.
« Last Edit: January 31, 2024, 01:50:30 pm by jdev99 »
Offline Randy222
« Reply #5 on: February 01, 2024, 09:34:08 pm »
What are you using the RD for or on?
One method is to park two motorcycle 12v batts in series under desk, send 24vdc to the RD.
Then just attache a small "smart" batt-tainer to each batt, turn on the charging when you not using the RD.
The dc-dc warts are gonna be noisy, but you can perhaps tack on a fat cap to the dc input of the RD, and add a few twists of the supply lines around some iron.
