Hello, hope you are doing well!
Today I want to start a new project for my hobby: eurorack synthesizers.
The problemEurorack is an electronic musical instrument standard, you can buy (or DIY) analog or digital instruments from a lot of brand. They are all placed into a rack, and they have share the same power supply, the PSU of the rack, delivering a rail of -12V / GND / +12.
Some instruments are well designed of not. Sometimes in the sound output of an instrument you get 10khz noise, 15khz noise... it can be caused by ground loops, how instruments are placed in the chain, the intensity of leds of one instrument that you can "hear" on an other instrument, the "CPU" noise, ...
The difficulty is that the source of noise can be multiple and depend of what instruments you have.
My ideaI want to make a power supply filter, that can be placed between the noisy instrument and the power supply rail, to lower the noise level.
After some research based on examples, I've create this design :
I've tested it today and it does not improve the noise.
I'm not sure of my design, neither the value I've used. Maybe you have some guidelines for me?
Thanks a lot, have a nice day!
