Author Topic: Powerpole connector question  (Read 2776 times)
Offline cncjerryTopic starter
« on: June 06, 2018, 06:12:43 pm »
I need to feed 48V at 30A to a chassis of my design.  I would like to have a disconnect so I was looking at PowerPole PP30 connectors.  Do they connect together or is there a male/female equivalent?  Also, I need a chassis or panel mount for the box.  If someone has the part number that would take the PP30 or other sized powerpoles that would handle the current, that would be helpful.  I was planning to use a blue and green PP30 for the power (can also use black) and if I don't need male/female, I was going to just hook them from the feed cable into a panel mount connector but I don't see the panel mount on mouser.  I see some 'E' shaped clamps that will work fine.
Thanks
Jerry
Offline metrologist
Re: Powerpole connector question
« Reply #1 on: June 06, 2018, 07:59:07 pm »
Personally, I do not like power poles. XT60 is a good connector and I've seen a few different ways to accomplish a panel mount, like soldering it right to the board.
powerpoles are symmetric, just the plastic colors are different. Here is a bracket:
https://powerwerx.com/anderson-1462g1-powerpole-mounting-clamp
« Last Edit: June 06, 2018, 08:07:10 pm by metrologist »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: June 06, 2018, 08:09:58 pm »
Hmm, 1/4" QC terminals are in that range.  (Tons of screw and barrier terminals too, but if you want a tool-free connection, that doesn't apply.)
Seven Transistor Labs, LLC
Offline chris_leyson
  • Country: wales
« Reply #4 on: June 07, 2018, 02:22:12 am »
so are the powerpoles the same sizes for the various amp ratings?  I was going to use the blue connectors, PP30. I can always cut a clamp like that if they aren't, just trying to minimize the custom work.
Offline Bratster
« Reply #5 on: June 07, 2018, 04:11:24 am »
Pp15/30/45 are all the same housing just different contacts/wire size.
Sent from my Moto x4 using Tapatalk
« Reply #6 on: June 07, 2018, 05:41:19 am »
Thanks
