One of the members here has kindly agreed to help me make a LTC2400 experiment board. The main circuit will be based on fig. 4 in
http://cds.linear.com/docs/en/application-note/an78fs.pdf:
/?action=dlattach;attach=62038;image)
Over and to the right of the LTC2400 will be footprints for 2 reference chips and a 3 terminal regulator. This will allow the ADC and other circuitry to be fed by:
1. External 5 V (jumpers on the on board two refs and the regulator)
2. Any suitable 3 terminal regulator (jumpers on the two refs)
3. Any suitable 5 V ref or the low noise LTC1655-5
(... and all other combinations that makes sense by using jumpers/wires)
(... moreover - the LTC2400, LTC6655-2.5 (and a buffer op amp) can run on 3.3 V)
The capacitive front end can be used alone (or only half of it can be used) by putting a jumper for the op amp (please see the other circuit diagrams in the linked application note).
The op amp buffer - with or without a precision resistive 2-3 range divider - can be used alone by using jumpers on the footprint of the LTC1043.
Imo it will not be difficult to arrange numbered test points, jumpers and optional traces in a way that allows almost any circuit - from bare bone ADC with ref to a very high precision meter - to be made on the board.
There will also be room for a multiplexer front for people who does data logging of sensors or voltage references. All ideas will be gratefully considered. Guests can post comments on the latest/last video over. The Gerber files will be publicly accessible.
Trace layout, length, width, decoupling and ground will have to be discussed when the first layout is presented. Imo the schematic must be done first.
I will order a batch - hopefully by the end of this month.
