Hi guys,
I have been working on a preamp for my dynamic micro, based on 2 npn, i made a pcb etc, but it doesn't work
whereas on a bread board using BC546b it worked just fine, at least one stage, i didn't try to test with 2 transistors. Since i have not any scope, i just mesured the working point, it is about 7V with 9V vcc, it have shifted a litle bit. In theory i calculated the resistors to have 5V (~Vcc/2).. i can't understand why i have nothing on the output. I put some pics of the pcb and schematic if you want to see them.
