Author Topic: problem with Eagle  (Read 3889 times)
Offline elektrodaTopic starter
problem with Eagle
« on: September 21, 2016, 04:42:18 am »
hi , I have problem with eagle . How move part of element from one to second sheet. I am going to  move part of contactor ( i mean contact ) from one sheet and I want to leave coil at this sheet. do "eagle " has this possible? in Eagle don't function "cut" , why? I asked about answer at other forum , and I wait here.
I am learning English . If I am writing bad ,please correct me ..
Man is learning all time, and stupid die.
Offline technotronix
    • PCB Assembly
Re: problem with Eagle
« Reply #1 on: September 21, 2016, 05:54:39 am »
Did you tried with EAGLE 5? See "help move" for all the details. Hold down shift key when moving and you can move an item or group between
sheets.
« Reply #2 on: September 21, 2016, 07:02:04 am »
don't work, don't work any combinations keys shift, ctrl  and  alt. Maybe who has any idea , how do it?
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: September 21, 2016, 07:10:34 am »
You just move the group to another sheet in Eagle 6, no keys required.
  • Group.
  • Move group.
  • Click on sheet.
  • Place.
Offline matseng
    • My Github
« Reply #4 on: September 21, 2016, 07:15:37 am »
You have one (1) component and you want to split it into two parts and put them on different schematics pages?
I don't think you can do that unless the component is a pre-made multipart component (like a dual opamp) where you have  to use the "invoke" command to place the second part.
A relay component is almost for sure not made in that way.
« Reply #5 on: September 21, 2016, 07:27:26 am »
ok , I want move one amp ( preamp has for example two) form sheet to sheet . I want have two amps at two sheets. How do it?
Online H.O
« Reply #6 on: September 21, 2016, 07:32:07 am »
What, why? A relay component, if anything, most certainly should be made this way. How often do you want the coil next to the contact(s) in the schematic?
But of course the complete device must be created (in the library that is) from multiple symbols, (a coil and one or more contacts) if you create the device yourself and draw everything as one symbol then obviously it won't work.
As for moving parts between sheets, I'm limitied to one sheet here so I can't test, sorry.
Online Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #7 on: September 21, 2016, 07:33:29 am »
You have 1 symbol for a duo amp? There's your mistake.
Add two symbols in the device editor and connect them to one package.
« Reply #8 on: September 21, 2016, 07:46:33 am »
you see for example gates from 7400 , you have four single gates , and every you can move   on the schematic.  every gate is as single , but all are in one IC. And simillar i want move one gate from one sheet to other sheet. I dont want copy . I want have one gate as same name as three others. I want "cut" and "paste"
« Last Edit: September 21, 2016, 08:24:02 am by elektroda »
Offline electrolust
« Reply #9 on: September 21, 2016, 09:23:43 am »
You can't move an individual object of any kind.  You have to define a group then move the group.  You can just define the group to be the single element you wish to move.
You should have posted this in the eagle forum, not the projects forum.
« Reply #10 on: September 21, 2016, 09:30:37 am »
for admin , please  transfer this post to eagle forum
