Author Topic: Problems trying to develop a stepper motor driver with TB6600  (Read 1098 times)
Offline SERGIO_372Topic starter
  • Country: br
Hello, I am developing a stepper motor driver using the TB6600HG. However, when I plug the motor, all I hear is a faint buzzing sound, and the motor does not rotate. When I send commands to rotate, I can hear a subtle sound, but the motor still does not move.
This is the first time I am trying to develop my own hardware, I will post the schematic.
The step motor is a NEMA 23 model 23HS5628
What I have done so far:
- Tested the motor with a driver I had already bought, and it worked perfectly.
- Replaced the TB6600HG and got the same symptom.
- Soldered the components onto a board, as I thought there might be a bad contact or interference on the breadboard, but the problem persisted.
- Tested with different microstep configurations.
Could someone help me understand what might be happening? Did I design something incorrectly? What am I missing?
Offline Benta
Re: Problems trying to develop a stepper motor driver with TB6600
« Reply #1 on: June 22, 2024, 09:00:22 pm »
You seem to be powering things from the Vreg pin.
I don't see that as possible from the data sheet. In fact, quite the opposite.
If you have an external +5 V supply, it should not be connected to Vreg like you've done.
« Last Edit: June 22, 2024, 09:03:19 pm by Benta »
The following users thanked this post: SERGIO_372
  • Country: br
« Reply #2 on: June 22, 2024, 10:52:48 pm »
You are absolutely right. And yes, I'm using 5V from an external supply. I removed the external 5 volts from VREG. I also noticed that the sounds the stepper motor was making were because of the poor quality of the 5V supply (ripples). Fixing those issues made the driver work. Thank you.
Offline Benta
« Reply #3 on: June 22, 2024, 11:13:34 pm »
