Author Topic: Programmable Power Supply Digital Interface  (Read 21389 times)
Offline Perpetually_DebuggingTopic starter
« on: March 30, 2017, 05:54:17 pm »
Good day all!
This is my first post on these wonderful forums, so I apologize for any unintentional breach of etiquette, incompetence, or just asking dumb questions.
I'm in the process of designing a LT3081-based programmable power supply for the lab, and I'm having trouble working out the digital interface for the device. From what I understand, I can feed a set voltage straight through into the SET pin, and this drives the non-inverting input of the error amplifier. There is an internal 50uA current source upstream of the pin, which allows the voltage to be set very easily by a pot between set and ground. However, I don't want to use a pot, I'd like to have the thing controlled by a DAC (driven by an external reference) to program the voltage precisely. This leads to my first question:
Would it be possible to take the output of the DAC, scale it with an opamp to get the full voltage range of the regulator, and then run it into the SET pin? My concern is that the gain resistors will provide a path to ground from the current source, and there will be a voltage on SET that I didn't put there. And if this is the case (and will affect operation) would it be wise to put a buffer after the opamp to remove this path to ground, and then I wouldn't have to worry about the current source?
Second, I don't know how to digitally interface to the ILIM current setting pin on the LT3081. The datasheet only shows applications with a resistor or a pot between ILIM and VOUT, and I'm curious as if and why it needs to be tied to VOUT. I've seen people set the current limit digitally, by using a current mirror, and driving the controlling side with a current source, as shown in this project:
https://hackaday.io/project/12763-vederpsu#menu-description
Is this the best way to go about controlling the current limit, and is the current mirror necessary? I can understand using it for some isolation to protect the opamp maybe, but that's its only purpose that comes to mind. Also, would adding any of this circuitry cause the regulator to oscillate, and potentially cause large problems?
I know I could use a digital pot in order to program the thing easily, but I'd like a lot more resolution than what even the 1024 step ones can provide.
Lastly, I've heard that the 3081's current set is heavily temperature dependent and somewhat useless. Would it be worth having the 3081 running as a voltage regulator only (using internal current limiting only) and use some kind of current source/limiter device connected to the output? I'd like to stick to using the 3081 for voltage regulation because it can go down to 0V, and can be easily paralleled for the final implementation.
Thank you all for tolerating my long post  :blah:, and for any advice you give!
-Perpetually Debugging
Online David Hess
  • DavidH
Re: Programmable Power Supply Digital Interface
« Reply #1 on: March 31, 2017, 02:36:00 am »
The output resistance of the operational amplifier when it is driving its feedback network is essentially zero and this is the resistance that the SET pin current sees so no offset voltage is generated.
However in a better design, the output of the LT3081 drives the operational amplifier's feedback network and the output of the amplifier drives the SET pin so offset errors in the LT3081 are removed.
The current limit is obviously referenced to the output voltage but I could not find any internal details.  It *has* to be this way because the output pin of the regulator is its common; all of the internal circuits operate at or above this point.
As shown in the hackaday example, they set the output current limit to the minimum by using a low Ilim resistance and then add a current to Ilim to raise the output current.
It is not for isolation; the Ilim pin needs to be driven positive (above OUT) to increase the output current and doing so with a current allows it to follow the output voltage exactly.
If the LT3081 is used inside of a feedback loop for greater accuracy, then frequency compensation will be needed to prevent oscillation and produce the best transient response.
Driving Ilim with a current and shunt resistance and Iset with a voltage outside of feedback loops should be pretty safe but not nearly as accurate.
That is what the datasheet shows; it is not a precision current limit.
I think if you want precision current limiting, then the best way is to use a separate precision current shunt and error amplifier to either override the voltage loop error amplifier or drive the Ilim pin with a current like shown in the hackaday example.  An optocoupler might work as well as the PNP current mirrors in the hackaday example but PNP current mirrors are trivial and accuracy is not a problem.
I think driving Ilim will produce a higher output resistance which is good for current limited operation but in most applications this will not matter.
And on the subject of output impedance in constant current mode, take a look at the small value of the output capacitance.  Check out National Semiconductor linear brief 28 for an example of a power supply design which uses even less output capacitance and an integrated power stage which is oddly similar to the LT3081.  I wonder if Linear Technology got the idea for their single resistor programmable regulators from the National LM395.
The following users thanked this post: Perpetually_Debugging
Offline prasimix
  • Country: hr
    • EEZ
« Reply #2 on: March 31, 2017, 06:39:44 am »
You have a LT3081 programmable power supply (EPSUX3V2) designed by Frex with both voltage and current programming here. A complete history can be found here.
The following users thanked this post: Perpetually_Debugging, Pitrsek
Offline Kleinstein
« Reply #3 on: March 31, 2017, 07:37:15 am »
Using a voltage regulator chip to build a lab power supply has it's limitations:
The loop stability may not be that good, as the regulators are made for well behaved loads. A lab supply is supposed to work with essentially any load.
As there are no separate feedback pins, all resistance outside the chip will add to the output. Lab supply circuits can use voltage sensing more or less directly at the output posts.
The reference (here only for current limiting) is inside the chip and thus sees considerable temperature swing. So there will be quite some temperature drift from self heating.
The power is limited - paralleling chips is problematic and expensive. So while possible in theory more than one chip is not really practical.
Adding external current limiting (or more accurate voltage control) it calling for trouble with loop stability. It is possible, but usually not easier than building a proper lab supply from scratch with OPs for control and power transistors.
« Reply #4 on: April 01, 2017, 02:14:59 am »
Thank you for the quick and helpful replies!
Aha! Is that effect of an essentially zero output resistance caused by something similar to how a virtual ground occurs?
I'm not quite sure what this would look like on a schematic, perhaps something similar to this?:
If I was to use a precision current shunt and error amplifier to drive the Ilim pin, would this induce any instability in the loop? I would think that it would introduce at least some small phase shift, as there is a non-zero delay in the amplifiers, but I could be wrong. I think such a circuit would look like this:
I've got IC1 amplifying the voltage off of the shunt resistor, and IC2 controls the current mirror which drives the current limit of the device. IC3 is configured as a differential amplifier (I think) and will output a voltage proportional to the difference between the DAC's setting voltage and what the how much current is being drawn, as according to the precision shunt. This will drive IC2, making the current through ILIM follow the error between the DAC's voltage and the voltage off of the current shunt. I have no idea what the stability of this loop will look like.
Hopefully some of that might work, let me know if I've made any mistakes or if there is a simpler/better way to do it.
Also thank you for the links to Frex's supply, it looks oddly identical for the Vset and Iset sections from the hackaday link.
Thank you all again!
Online David Hess
  • DavidH
« Reply #5 on: April 01, 2017, 02:38:06 am »
That is the same design Perpetually_Debugging linked although looking at the alternative schematic, I found an error.  The current mirrors which allow setting the output current and current sharing are configured wrong so there is considerable current sharing error.  The amusing part is that they used matched transistor pairs for each current mirror but then defeated the matching by using two separate current mirrors in parallel.
Offline Kleinstein
« Reply #6 on: April 01, 2017, 07:41:27 am »
Adding an extra loop for more precise current limiting can be tricky and cause instability. One point in the circuits shown here is that the external loop will go into saturation when the current limit is not active. This will cause a significant delay before the current limit will start to work as intended.
The circuit shown by Perpetually_Debugging has an additional problem with IC3G1, as this will be running at open loop gain (no working local feedback). But the whole circuit is not worth fixing it.
Better build a lab supply from scratch.
Online David Hess
  • DavidH
« Reply #7 on: April 01, 2017, 09:58:50 am »
Yes, the open loop resistance, including the feedback resistance in a virtual ground, is divided by the difference between the open and closed loop voltage gain.  Since the open loop voltage gain is very high, the closed loop output resistance is very low.
Sort of but eliminate the link between R1 and R2.  Actually, the frequency compensation network if needed goes where that link is.
You have identified the problem.  If the phase shift reaches 180 degrees before the gain drops below unity, then that plus the 180 degrees from the negative feedback creates an oscillator.
The stability would be poor with three operational amplifier stages in series requiring good frequency compensation.  With some cleverness, all of them can be combined into one integrator.
Ground referred current sensing makes things easier if its limitations are acceptable.  But take a look at the design of the Tektronix PS501 power supply to see an example where the current sensing is done on the output of the power stage with only one error amplifier inside the current control loop.
This kind of design is not trivial for a beginner but you can learn a lot getting it to work.
They are practically identical.  They even have the same mistake in the current mirror.
Online David Hess
  • DavidH
« Reply #8 on: April 01, 2017, 10:15:03 am »
The National Semiconductor example I linked clamps the error amplifier for the current control loop using the operational amplifier's external compensation pin.
Most designs manage without clamping the error amplifiers but they also have more output capacitance which allows more time for recovery at the expense of lower AC output impedance which is good for voltage control but bad for current control.
« Reply #9 on: April 03, 2017, 04:34:48 pm »
Thank you David and Kleinstein, and I apologize for the delayed reply, this last weekend produced a rather large amount of homework.
What would be some good resources to look at to design the thing? Most of the designs I've seen are quite different from each other, and it would take some time to figure out how each would work, and I'd like to make sure I'm learning from good designs. Also, would a 723 work, and do you think I could control it digitally, precisely, and easily (or at least more so than the 3081).
I did some more thinking and I'm curious if this circuit would be any better:
I think I've configured the opamp as a differential amplifier, and assuming I keep it in unity-gain, the voltage off the DAC will equal the voltage on the shunt. I've reduced it to a single opamp so I think the phase shift should be pretty low, and hence the loop would be stable. My only concern is that the low voltage produced by a shunt (100mV/A for a .1 \$\Omega\$ shunt) would have to amplified by an Opamp for it to be non-miniscule, increasing the phase shift. That or make the shunt 1 \$\Omega\$ so that I'd get 1V/1A, and then the voltage I'd have to set the DAC to wouldn't be in the mV range. This would have the effect of increasing the output impedance, but I think that (and correct me if I'm wrong) 1 \$\Omega\$ would still be okay.
What are the limitations of ground referenced current sensing? Only thing I can think of is that the negative terminal of the supply wouldn't be at ground, but it will be pretty close to it.
This leads to a fairly stupid question: should I clamp the opamp, or somehow prevent it from going into saturation? How would I do so, just a diode on the output?
Lastly, the accuracy of the set pin varies 15% in either direction over temperature. I don't believe I mentioned this before, but I intend to insert a tracking switching pre-regulator upstream of the 3081 just like in the hackaday/Frex link. The power dissipated by the LT3081 will be the 2V overhead mulitiplied by the output current, which is a maximum of 1.5A per regulator. I have some large copper heatsinks that I can use, and if each regulator is only going to be pulling 3W maximum, I think these heatsinks will be able to keep the regulator fairly cool. If I can keep the regulator within a narrow temperature band over all load currents by over-engineering the heatsink, then would it be possible to have a fairly precise current limit(±5%)?
Thank you all again for your patience and insight!
Offline Kleinstein
« Reply #10 on: April 03, 2017, 05:19:21 pm »
The main limitation of adding an external shunt to the LT3081 circuit is that it could add to the output impedance. Also Stability of the extra loop is tricky, as there are no accurate data on how the set current input is behaving.
Avoiding saturation of the external loop is rather tricky - a simple diode only avoids the OP itself to reach saturation, the compensation capacitor (still missing in the plans shown) would still charge up a lot.
I know there are a lot of lab supply designs, good ones and also quite a lot of bad one on the web. There are mainly two classes of supplies:
1) one with a low output impedance power stage (e.g. the TEK PS501 mentioned before and many 723 based designs). They typical have an Emitter follower for output and are often limited to something like 30 V maximum output as the controlling OP limits the voltage range. Voltage control is usually good, but current control can be problematic.
2) Designs with a high impedance / current controlling ouput stage. These usually use a second supply (e.g. transformer) for the control circuitry. Most of the HP linear lab supplies use this system. The Advantage of this system is that it is very flexible with the voltage range: essentially the same control circuit type can be use for 3 V or 200 V (just change resistor values and power transistors). Here current control is usually better, but voltage control might be a little slower.
Taking the schematics of a commercial available supply as the basis might be a good idea. The TEK PS501 seems to be relatively simple, though limited in voltage. For the second class, something many of the cheap chinese seem to use this type, e.g. the "Mastech" and others HY1803D (using BJTs). There is also a plan available for the GW Instek 3303S (using MOSFET, though it has a few minor issues, especially with channel 3/4).
The LM723 has somewhat similar limitations to the LT3081: the original current control is poor (cold be even worse than the LT3081) and adding more precise current regulation is difficult, though easier than with the LT3081.
For a start, I would avoid using a pre-regualtor: this adds quite some difficulties. It is only needed to get high power from the small LT3081.
Online David Hess
  • DavidH
« Reply #11 on: April 06, 2017, 07:04:56 pm »
You can learn a lot by studying fully documented designs like the Tektronix PS501 and PS503 and various older HP power supplies.  The National Semiconductor application note that I linked for the LM395 has a lot to teach.
A 723 integrates an error amplifier, reference, driver, and current limit protection into a single package.  It could be used as part of a programmable power supply but I am not sure if it would have any advantage over separate functions.  I might use one as a low cost alternative to the LM399 reference by configuring it to operate itself at a constant temperature using its output transistor as a heater.
The error amplifier needs high gain at low frequencies like an integrator so replace R5 with a capacitor; this location is the principle place where the frequency compensation is adjusted.  Depending on the maximum level from the current shunt, divider R3/R4 is not needed.
The low signal level has no effect on the operational amplifier's frequency response.
It moves ground away from common which is inconvenient in some designs like bipolar tracking and programmable regulators.  In your example schematic, now the output voltage compared to common has an offset which depends on the current.
Since the objective of clamping is to prevent windup of the error amplifier's integration term, what has to be done is a modification to the feedback loop so that once the amplifier's output is no longer controlling the regulator and would be operating open loop, instead it drives its inverting input.  The integration term is provided by any external capacitance between the output and inverting input and by the frequency compensation capacitor inside the amplifier.
In the example schematic I linked, one of the amplifiers supports external frequency compensation giving direct access to the internal node where the frequency compensation occurs but that is not strictly necessary to do this.  The clamping can be done completely externally; this comes down to shorting the output to the inverting input when the amplifier is not controlling the output.
Most power supplies simple ignore this (the Tektronix power supplies have no clamping) but it becomes more important if the output capacitance is low which is good for current limit performance.
5% might be possible under those conditions but most constant current outputs are much better than that.  In practice 5% or even 10% would be good enough for most applications anyway.
« Reply #12 on: April 07, 2017, 04:54:36 pm »
I binge-watched most of Dave's series on the uSupply, and I believe that his architecture where he controls the current out of the regulator by a comparator-controlled transistor off Vset will perform quite well, from seeing his testing and as the ILIM behavior of the 3081 is unknown.
I'll also take a look at some of the older HP power supplies later on, but I modified Dave's supply for the LT3081, and paralleled two of them for a 3A max output. I have about 80 IE0512S isolated DC-DC converters laying around, and I have one configured as a negative voltage supply from which a LT3092 current source is run off of, and that draws 10mA from the output of the 3081s so they can regulate down to zero. The schematic is attached.
Note: the Opamps I have in there are LM358s, which aren't rail to rail, I would replace those with a rail to rail part in the actual device, just grabbed the first opamp in Eagle.
I don't think Dave had any saturation problems (at least that he mentioned by part 4  :)) and since I basically copied his I think I should be good. The internal current limit/thermal shutdown of the 3081 is still active. Would the output impedance of the supply include the shunt resistor, because it's on the input of the regulator? I don't think so because the transistor inside the 3081 is basically acting as a resistor too, and we're only concerned with the resistance on the emitter to ground. The 10m \$\Omega\$ ballast resistors will count for output impedance I think.
Dave's (and mine too now I guess) supply gets around this by having a high-side current sense, and he's got a differential/instrumentation amplifier off of the shunt. Would there still need to be a frequency compensation capacitor, maybe in parallel with the gain resistor on the AD623?
Upon reconsideration, I think I will do just that. I'm not terribly concerned about efficiency and I already have the heatsinks, why buy more parts and physically isolate the RF from the rest of the board? Can't be bothered...
If this design looks like it'll work, I'll get the thing soldered up and give 'er a go!
Thanks again guys!
Online David Hess
  • DavidH
« Reply #13 on: April 08, 2017, 09:38:36 pm »
I usually try to avoid rail-to-rail operational amplifiers because they cost more and usually compromise performance and in the case of a power supply where extra bias supplies are easy to include, they are not really needed.
The one exception might be for high side applications where the common mode input range needs to go to the positive supply although this is usually where they have precision problems.  (1) There are some non rail-to-rail input operational amplifiers which have a common mode range which extends to the positive supply like the ancient LM301A and various JFET amplifiers (TL051 series, LF351, LF355, LF356, LF357, LF441) so this can be avoided if necessary without a positive bias supply.
High power current shunts tend to limit accuracy so this might not be such a large problem.  1mA out of 1A should be barely possible but beyond that requires heroic efforts.  A temperature change of 20C with a 50ppm/C shunt is 1 part in 1000.
No matter where the current shunt resistor is, the difference between the error amplifier's open and closed loop gain divides it (I'm simplifying) and at high frequencies, the output impedance is determined by the output shunt capacitor.  For high accuracy, the current shunt needs to be on the output (2) and if the output is an emitter follower, then the increase in impedance can actually be an advantage for stability.
Adding a separate difference/instrumentation amplifier (3) will make compensation more difficult as I learned with my first lab power supply.  I ended up needing so much compensation that the current limit performed poorly as far as speed.
I think the best overall configuration is how Tektronix did it with the PS501/PS503.  Use high side current sensing on the output but instead of using a difference/instrumentation amplifier to create a ground referenced high speed current signal, do the opposite and reference the slow current control level to the high side and float the current error amplifier to follow the output.
Now the problem becomes how to do a precision level shift of a slow signal to the high side instead of a fast signal to the slow side.
If elevating the negative output from common is not a problem, then just sense the current on the low side.
If the heat is not a problem, then a power transistor cascode could be added to the input of the regulator or a transistor current amplifier could be added to the regulator to bypass some of the current.  But this calls into question whether an integrated regulator should be used at all.
(1) I think TI has some rail-to-rail input amplifiers where you can move the input threshold to solve this.
(2) I think some of the HP power supplies placed the current shunt on the input side of the pass transistor and then compensated for the base current error.  Today a FET could be used to reduce the error.
(3) Differential amplifiers are a difference beast.  I know differential, difference, and instrumentation amplifier are often used for the same thing but differential is really confusing because there are real differential amplifiers which have nothing to do with difference and instrumentation amplifiers.  In the past, differential amplifiers were sometimes confusingly refereed to as push-pull amplifiers and push-pull has a completely different meaning now.
Offline Kleinstein
« Reply #14 on: April 09, 2017, 09:04:12 am »
In the LT3081 circuit, any shunt / current sharing resistor behind the output will usually show up in the output impedance. So using 2 of the LT3081 is not such a good idea. In an conventional supply the drop at the shunt is compensated by the regulation loop.
The modified LT3081 based circuits has some problems: the lt3081 might not like the shunt on its supply side, stability can suffer from this. Also the current measured at the input side may not be exactly the same as on the output side.
In a power supply there usually is no need for rail to rail OPs. Some circuits might want a single supply OP like the LM358, though the LM358 can be tricky sometimes.
The difference in having the shunt at the high or low side is not that large. In a conventional supply with emitter-follower type output stage the shunt at the low side makes current regulation easier and voltage regulation a little more difficult. The Tektronix PS501/PS503 looks simple, but relies on the common mode rejection of the OP used for current control - so it needs care on what OP to use there. It is elegant in a way making the constant current response relatively fast, despite of using the emittter-follower structure.
« Reply #15 on: April 11, 2017, 03:49:31 pm »
A normal opamp it is then.
If the amount of frequency compensation on that instrumentation/difference/differential amp would be problematic and it would be better to reference it to the high side, would it be possible to accomplish that precision level shift by using a differential amplifier to "subtract" the current setting voltage from the high side? If that works, then it would be possible to omit any frequency compensation on the "subtracting" amplifier as the signal (from DAC or a pot) is slow?
After studying the schematic for the PS501, I'm wondering if there is any advantage to using a diode OR gate instead of the transistor/resistor configuration that Dave's got in the uSupply? Less noise, perhaps?
Feel free to correct me if I reference the wrong kind of amp, and you're right, it is rather confusing  :)
If I parallel two 3081s with a shut at the high side of the output, do you think they would have any problems? I believe they would have some voltage error due to the drop across the shunt resistor. Another reason to build it out of discreets I guess, can just sense the output voltage past the shunt and then the compensation is done inside the feedback loop of the voltage regulating opamp.
Thanks again everybody!
Offline Kleinstein
« Reply #16 on: April 11, 2017, 04:44:36 pm »
There is no big difference in combining CC and CV control through 2 diodes or a resistor and transistor. With the transistor one can be limited by the base-emitter voltage in reverse. Dave's circuit has the difficulty that the transistor adds gain to the current loop. This can make compensation difficult.
It is possible and sometimes an advantage to transfer the reference / set signal to the high side in stead of the measured current signal. The Tek. PS501 kind of does this by using a current source to set the current limit.
Having a kind of slow amplifier is also a kind of compensation. The usual way frequency compensation is done to make the slowest amplifier stage in the loop even slower. With modern OP without provisions for external compensation, this is usually be adding a capacitor in feedback, making the OP a kind of integrator or PI (sometimes neglecting the P part, which may not be good) controller. With old OPs like the LM301 that use external compensation, one could also add the compensation at the corresponding pins of the OP and thus make the OP itself slow.
Online David Hess
  • DavidH
« Reply #17 on: April 12, 2017, 12:12:35 am »
It is an instrumentation/difference amplifier and not a differential amplifier.  Differential amplifiers have two inputs and two outputs.
Using an instrumentation/difference amplifier will work but there is an easier way.  Convert the current control signal to a current and pull that current from a resistor connected to the positive supply to create a voltage referenced to the positive supply.  This avoids the resistor matching requirements to produce high CMRR in an instrumentation amplifier and is less expensive.
The PS501/PS503 sort of work this way but they use a constant current to create a high side voltage reference for the current control operational amplifier.
Kleinstein identifies the problem with the way Dave did it; common emitter connected Q2 adds voltage gain which would normally make the current loop unstable.  The only reason it works is that R12/C2 operate as a low pass filter producing dominant pole compensation but this also makes the current control loop slow.
A pair of diodes like the PS501/PS503 use is the simplest way.  I like using emitter followers to buffer the amplifier outputs and diodes to protect against base-emitter breakdown if necessary.  The collectors of the transistors can drive LEDs or a logic circuit to display the operating mode in real time.  The next step up from that is to include clamps around the amplifiers to make the switching between voltage and current control modes as fast as possible.
If I parallel two 3081s with a shut at the high side of the output, do you think they would have any problems? I believe they would have some voltage error due to the drop across the shunt resistor. Another reason to build it out of discretes I guess, can just sense the output voltage past the shunt and then the compensation is done inside the feedback loop of the voltage regulating opamp.
I am a little fuzzy on exactly how the LT3081 current sharing as shown in the Linear Technology application note works but I do not think there will be any problems using an external current shunt.
The voltage feedback loop compensates or can compensate for the voltage drop across the current shunt on the output.
« Reply #18 on: April 12, 2017, 04:22:35 am »
I'm having a hard time visualizing what you're describing, perhaps something like this?
And then once installed in the system it would look like this:
Not sure if that's what you had in mind, please correct me if it's not.
Aside from buffering the output and allowing for status LEDs/logic, is there any other benefit to adding emitter followers? And what would that clamping look like? Perhaps putting a diode with a lower forward voltage (schottky) inside the feedback loop, or maybe just using schottkys for the OR gate?
Would this circuit need any frequency compensation? I think it still would, and if that takes the form of a cap on the inverting input (inside the feedback loop) then that would be really easy to test and adjust.
Also I'm thinking of using essentially that same circuit in the final supply (plus DACs and ADCs of course) and if there's anything else wrong with it please let me know.
Online David Hess
  • DavidH
« Reply #19 on: April 12, 2017, 09:44:09 am »
The MOSFET and operational amplifier make a current sink going to ground or the negative supply so operation down to ground is possible.  The drain of the MOSFET connects to a resistor which itself connects to the upper side of the current shunt.  So now the error amplifier has a reference voltage which follows the output voltage.
So there are two precision resistors, one in series with the source and the other in series with the drain, and their tolerance affects the gain and not the common mode rejection ratio.  The operational amplifier and MOSFET make a voltage to current converter and then the high side resistor converts the current back into a voltage for use by the current loop error amplifier.
I might put a capacitor across the top resistor for lower noise and to prevent some odd things from happening when the output voltage shifts rapidly.  This would limit the speed at which the current limit could be changed but would have no effect on the speed of the current error amplifier
The emitter followers allow the set pin current to be high and independent of what the operational amplifiers by themselves can drive.  Schottky diodes would only have the advantage of increasing the compliance a little bit with their lower forward voltage drop; that might be necessary if a negative bias supply is not available for the operational amplifiers.
There are too many ways to do the clamping.  Basically they come down adding another feedback path between the output and inverting input of the amplifier forcing it to unity gain when in this case the output rises above the output of the other amplifier.  This prevents the output from rising and charging the feedback capacitor and internal compensation capacitor up which is refereed to as "wind up".
These are referred to as "anti wind up" circuits.  I looked online and did not find any examples for a power supply (except for the National Semiconductor example which is high performance) but this just reflects how unimportant it is in most applications.  They are only needed if the original design was poor or if the highest performance is required.
The National Semiconductor application note that I linked shows another way to clamp the amplifier by driving the compensation pin but it is not easy to understand and requires an operational amplifier which supports external compensation which is rare these days.  Some very specialized operational amplifiers have external clamp pins to implement this function.
With slow amplifiers like the 324/358, 741, and OP-07, compensation will probably not be needed.  Faster operational amplifier like the LT1007/OP-27 and most JFET input amplifiers will require frequency compensation.
Even if frequency compensation is not absolutely required, adding it will improve performance.  Testing can be done with a function or pulse generator and oscilloscope so it is easy enough to do.
« Reply #20 on: April 15, 2017, 05:40:32 am »
I think I've got it now, would it look like this?:
R3 and R4 are the precision resistors of which you speak. I also added the emitter followers on the error amplifiers' outputs, as well as some LEDs to indicate CV/CC modes. Let me know if I misconfigured anything.
If there's that much trouble around clamping and the benefit is marginal, then I won't worry about it.
If I were to include frequency compensation (in the form of a capacitor on the input) would it better to use a slower or faster opamp to begin with? I'm thinking a OP-07 to start, and then add capacitance as needed.
What would that look like? Driving the base of a power BJT or MOSFET and using that as a dummy load? Basically just the emitter follower voltage regulator, but the non-inverting input of the opamp is driven with a pulse or some other waveform?
Thanks again guys!
Online David Hess
  • DavidH
« Reply #21 on: April 15, 2017, 09:43:51 am »
Exactly like that.
In the past T4 would be a JFET driving a bipolar transistor but now we have MOSFETs.
D1 and D2 are backwards.  I do not think R2 does anything useful.
Depending on the details, the fault current through the LEDs might be excessive.  On the PS501/PS503, the drive from the error amplifiers is reversed so PNP transistors would be used and there is a current source between the collector and base of the output transistor making it "normally on".  So the error amplifiers pull the output down instead of pushing it up.  This sets the maximum current the PNP transistors and LEDs can see under all conditions.
As you design is implemented however, it will certainly work and it has the advantage of not requiring a negative bias supply to get down to zero volts output.  R7 and R8 could be combined and then even better, replaced with a constant current source protecting the LEDs.  Under normal operations, the current source would be saturated; this might be a good place for a JFET current source or constant current diode.
That is a good way to start.
One thing to beware of is that precision amplifiers like the OP-07 and OP-27 have back to back protection diodes across their inputs.  On your schematic this means adding a resistor in series with the inverting inputs which is needed anyway as part of any external frequency compensation.
358, 741, and JFET operational amplifiers have no such requirement but still need the resistor in series with the inverting input to implement external frequency compensation.
Either way works.  Just weakly coupling the output of a square wave into the non-inverting input of the voltage and then current control amplifiers to shift the output voltage or current by a small amount is sufficient.  Then the output load can be varied to test stability with different loads.
Or since your design is programmable, have the processor adjust the voltage DAC and current DAC to do the same thing if they are fast enough which isn't the case for your current control loop with C1 in place.
Offline Kleinstein
« Reply #22 on: April 15, 2017, 09:58:46 am »
Combining the signals does not work this way: The diodes are the right direction to get an output that corresponds to the minimum of the two possible control loops. So the transistors need to be changed to PNPs (or left out) and it needs a current source or resistor to provide some base current to the output transistor.
The current source for setting the current limit still needs a negative supply, though just a little can be enough.
With slow OPs, there is chance it might work without extra compensation. However this would also make the CC mode rather slow.
Online David Hess
  • DavidH
« Reply #23 on: April 15, 2017, 10:29:01 am »
Whoops, you are right.  Many eyes make for fewer mistakes.
With the NPN transistors and diodes as shown, the output becomes the higher of the voltage and current limits.
Offline Kleinstein
« Reply #24 on: April 15, 2017, 11:31:41 am »
The external frequency compensation for the CC mode in the Tek circuit has a somewhat hidden advantage:
The compensation only slows down the change in current, the OP can react much faster (with the speed of the OP) to a change in voltage. This helps to speed up the response to something like a sudden short, where the output voltage is dropping fast. So using a slow OP instead of compensation for the current control gives away this advantage.
With this type of circuit (emitter follower and diodes to get the minimum voltage from both controls), the short circuit case is somewhat critical and needs a fast response of the control part (or a secondary current limit). Otherwise the base voltage will not drop fast enough in case of a short and would alow a high current spike, up to the point of destruction. A limited strength of the current source to provide the base current could be used as a backup current limit.
It is also much easier to adjust compensation by changing a capacitor or resistor than changing the OP type. So using a slow OP instead of extra R,C for compensation is not such a good idea. It may later still happen that the capacitance for compensation can be reduced all the way to zero. But it is a good idea to have the option to add compensation.
Adjusting the compensation is usually done with an external switched load or signal coupled into the feedback path. Switching of the set point (e.g. using the DAC for control) is somewhat different, and a fast response is not the same as a good loop response. The step test is better than nothing, but in principle the step response of the loop and set-point steps are different things.  For this simple circuit there is even the option to do it old style: Reduce the compensating capacitor until the circuit just starts oscillating. Form that point increase the capacitance by a factor of 2 to 3. To day there is also the option of doing a simulation up front - this at least gives a good starting point.
