Author Topic: programming ATMEGA328p using PICKIT3  (Read 15753 times)
Offline hussamaldeanTopic starter
  • Country: iq
« on: October 28, 2019, 03:11:40 pm »
Dear all,
I am currently learning MPLAB X to program both PIC and ATMEGA. anyway is there any way to upload the code to ATMEGA328p since I searched the web to figure out but I came up empty handed
regards
Offline Howardlong
Re: programming ATMEGA328p using PICKIT3
« Reply #1 on: October 28, 2019, 04:15:43 pm »
Dear all,
regards
Pretty sure that Pickit3 is for PICs only, it was developed well before Atmel became part of Microchip.
I did have some luck recently with a PICkit4 programming an ATTiny from MPLAB X, but it was reasonably hard work getting everything to work. In the end I went back to using Atmel Studio and an Atmel ICE, there are fewer unknowns that way. If you have to fight too hard with your debugging tools, IME you're probably better off taking a different approach.
  • Country: iq
« Reply #2 on: October 28, 2019, 04:18:52 pm »
Dear all,
regards
seems I will use arduino as ICP with gui-avrdude
Offline iMo
  • Country: li
« Reply #3 on: October 28, 2019, 04:29:07 pm »
This is a must for an atmel user :)
USBASP Programmer
Adapter (optional)
« Last Edit: October 28, 2019, 04:33:36 pm by imo »
  • Country: iq
« Reply #4 on: October 29, 2019, 04:46:32 am »
USBASP Programmer
Adapter (optional)
I have this but it doesn't work with MPLAB X  :-\ :-\ :-\ :-\
Offline iMo
  • Country: li
« Reply #5 on: October 29, 2019, 05:22:45 am »
FYI - GUI for your USBASP programmer
http://khazama.com/project/programmer/
« Last Edit: October 29, 2019, 05:24:23 am by imo »
Offline Ian.M
« Reply #6 on: October 29, 2019, 06:00:26 am »
IIRC AVRdude supports the PICkit 2, and if you use Microchip's  standalone PICkit 3 utility (see below), it will install PICkit 2 emulation firmware into your PICkit 3, which AFAIK is then good enough for AVRdude to see it.
Give it a try and report back please.
PICkit3 Programmer Application and Scripting Tool v3.10
Don't forget to use the utility to revert back to MPLAB mode (disable PICkit 2 emulation), before trying to use your PICkit 3 with MPLAB again (or simply hold the button down when plugging in the USB to force bootloader mode so MPLAB reverts it for you).
