Author Topic: project: extending HP3478A functionality  (Read 117452 times)
0 Members and 18 Guests are viewing this topic.
Offline kirill_kaTopic starter
  • Country: ru
Re: project: extending HP3478A functionality
« Reply #200 on: August 27, 2020, 09:31:51 am »
As someone may have noted :) The hp3478ext has a temperature measurement function.
It only supports 1kOhm 3850 ppm/K RTDs. The constants for which are hardcoded.
Yesterday I found a source of cheap sensors: https://aliexpress.com/item/32872179878.html
They look similar to the Honeywell sensor (700-102BAB-B00) that I have.
Offline momoFukushima
  • Country: jp
« Reply #201 on: November 15, 2020, 11:17:37 pm »
Hello kirill-ka,
I recently bought a used 3478A and found this very interesting topic that can expand the functionalities as well as the prologix compatibility during searching various knowledge about this tool. Visiting the Git-hub, I noticed the source program has been updated very recently but looks like the binary has not been updated yet. I would be appreciated if you upload the updated binary, since I am not familiar with the compiling at all.
Thanks
Offline Tj138waterboy
« Reply #202 on: November 16, 2020, 04:33:24 am »
Not sure if this has been asked on other post but will the artag style adapter work and or does anyone have the gerber for a known working pcb layout.
« Last Edit: November 16, 2020, 04:35:03 am by Tj138waterboy »
  • Country: ru
« Reply #203 on: November 16, 2020, 07:02:27 pm »
There aren't serious changes, but here you go: https://github.com/KIrill-ka/hp3478ext/releases/tag/r2.2
  • fixed ++ver command to actually show a version
  • added 250ms delay before trying to initialize the HP3478A during startup
    Attempt to read from the HP3478A too early caused a harmless error message to be displayed on the second try.
  • some minor error handling modifications
« Last Edit: November 16, 2020, 09:56:54 pm by kirill_ka »
  • Country: ru
« Reply #204 on: November 16, 2020, 07:12:26 pm »
Sorry, I'm not quite sure what do you want.
Do you mean using some AR488 hw to run hp3478ext or what?
  • Country: jp
« Reply #205 on: November 16, 2020, 09:42:58 pm »
Thank you very much for binary update, kirill_ka.
« Reply #206 on: November 17, 2020, 11:55:55 am »
For the purpose of plugging into gpib externally. I was thinking that would work the same from my understanding. Pretty much just needs 5v supply to arduino and buzzer.
  • Country: ru
« Reply #207 on: November 17, 2020, 03:42:06 pm »
The external connection is not a problem. The cheap atmega328p board+USB2UART+connector+bunch of wires will do the job.
AR488 hardware will not work straight away as it uses different pin assignments (at least).
Offline mcj7247
« Reply #208 on: January 09, 2021, 04:01:39 am »
Would it be possible to remap the pins to a custom layout in the AR488 FW to align with the HP3478A Control Software?
  • Country: ru
« Reply #209 on: January 09, 2021, 06:48:29 pm »
Everything's possible... Can you provide desired pin assignments?
Do you mean hp3478ext by the "Control Software" or something else?
« Last Edit: January 09, 2021, 06:54:10 pm by kirill_ka »
Offline mcj7247
« Reply #210 on: January 09, 2021, 09:30:03 pm »
[/quote]
I think I may have the various tools confused and apologize if I do. I think I'm referring to the HP3478A Control Software app developed by Steve1515, lmester etc.
« Reply #211 on: January 10, 2021, 08:46:57 am »
I just re-read entire thread and issue that seems to prevent using ar-tag adapter would be from post #105 the piezo/speaker pin. Also a reply from lmester pointed out you can't run both programs at same time, as from what I can tell all commands for the functions of 3478ext are manual button presses whereas the software mcj7247 shows in previous post is what I currently have been using and is ui controlled. It doesn't seem that the arduino sketch would allow both functions to work in unison due to the pin assignments as well as the user interface for the 3478 control software mcj7247 shows would have to be possibly recoded if you wanted a display.
« Last Edit: January 10, 2021, 08:52:28 am by Tj138waterboy »
« Reply #212 on: January 10, 2021, 08:50:02 am »
Also im not even sure a usb powered arduino could drive a speaker directly while performing as a gpib adapter. Never measured current draw from piezo.
  • Country: ru
« Reply #213 on: January 10, 2021, 10:32:09 am »
Correct. If the PB2 (or PB1) pin is not available, then more modifications required for the hp3478ext to work. However if the variable tone buzzer is not essential, the firmware can be modified to use any digital pin for the buzzer.
The lmester's "HP3478A instrument control software" does work with the hp3478ext firmware. It has nothing to do with the pin assignments. You can't simultaneously use the PC software and the extended functions (relative, continuity, etc.). Once you exit the PC software, the extended functions "assigned" to the SRQ key will be restored.
  • Country: ru
« Reply #214 on: January 10, 2021, 10:40:16 am »
An active buzzer can be driven directly by the MCU pin. I recommend adding a resistor in series.
The direct connection of a piezzo speaker will also work with a current limiting resistor, but the volume would be quite low.
A FET driver is recommended anyway.
Offline belzrebuth
  • Country: gr
« Reply #215 on: May 15, 2021, 01:23:43 am »
So now that this project seems mature enough shouldn't there be a PCB gerber available for it?
Just saying it would be far more tidy/safe to have this assembled outside and only do the absolute necessary soldering inside the instrument.
As I understand it Miti already done a PCB for it, maybe sharing it would be a good idea? ;D
Offline bywqdq
  • Country: cn
« Reply #216 on: July 20, 2021, 04:46:37 am »
Provide an idea to display the time when the multimeter is not operating. Add RTC to the circuit.
  • Country: ru
« Reply #217 on: July 20, 2021, 02:30:47 pm »
Hi bywqdq, welcome to the forum!
That would be so complex and inconvenient with an Atmega 328p.
However if you provide some alternative hardware, I might do something about it ;)
Offline bywqdq
  • Country: cn
« Reply #218 on: July 20, 2021, 11:07:19 pm »
I make one.
Offline yo0
  • Country: mx
« Reply #219 on: October 25, 2022, 04:10:58 pm »
The hex files are compatible with the Arduino nano?
I ask because I wired per the pin table in the GitHub to the conector but no luck.
If not what is needed?
Best regards
Pio
« Last Edit: October 25, 2022, 04:22:00 pm by yo0 »
  • Country: ru
« Reply #220 on: October 25, 2022, 06:18:44 pm »
Does it respond via serial (USB) interface? If it does, the second thing to check is the GPIB address.
Offline yo0
  • Country: mx
« Reply #221 on: October 25, 2022, 07:12:13 pm »
thank you,
no response, and the address is set #23, i triple check the wiring,
perhaps defective nano? it can be read, write and verify with avrdude and avrdudess
thank you in advance.
Pio
« Last Edit: October 25, 2022, 09:12:46 pm by yo0 »
  • Country: ru
« Reply #222 on: October 25, 2022, 11:05:15 pm »
It should respond to UART commands without any connections. Just the bare board.
Offline yo0
  • Country: mx
« Reply #223 on: October 26, 2022, 01:56:37 am »
I think yes it does. If I send text over serial monitor it appears in the console. I don't have experience with Arduino, sorry
I needed load a serial sketch to do that
ps.
i think maybe the problem is the wiring, do you know which pin at the external dmm connector is #1?, i mean seeing it frontally , the red wire at the ribbon cable usually mean pin 1 as far i understand, but.. seeing the schematic pin 1 at the socket is connected to ground, that don't make sense to me. or at least hp mount the internal connector backwards to avoid the ribbon be too near the transformer. in that case pin 1 really is at the other extreme of the socket (i mean near to the notch of the socket, usually pin 1 is at the notch side). or the socket is inverted, i am confused.
just an idea  :-//
Best regards
Pio
« Last Edit: October 26, 2022, 04:23:29 am by yo0 »
  • Country: ru
« Reply #224 on: October 26, 2022, 07:05:42 am »
It's good to know, that the UART works. But you'd get the response from the hp3478-ext firmware. Just to know that it's loaded and works.
It should respond with the <GPIB> prompt.
The connector pinout is standard. Just google "GPIB pinout". You'd find the pictures of the connector with the pin names and numbers.
