Author Topic: project: extending HP3478A functionality  (Read 118249 times)
Offline Miti
Re: project: extending HP3478A functionality
« Reply #275 on: June 03, 2025, 12:39:01 am »
Here are the Gerbers, the schematic, and the BOM for this project. Take the BOM with a grain of salt, check before you order.
I've never made this version of board but the changes from the one that I have made are minimal, adding a pull down resistor and changed the USB pin header from 4 to 5 pins.
« Last Edit: June 03, 2025, 01:17:51 am by Miti »
Fear does not stop death, it stops life.
The following users thanked this post: yo0, jozefch
Offline Vaionko
« Reply #276 on: September 02, 2025, 06:19:50 pm »
Thank you kirill for this awesome project! Getting continuity with this is actually the reason I got a 3478A, otherwise I would've gotten something else. After a bit of fighting with bad connections, it works! I don't have any equipment to plug into the GPIB port, so I took the whole port out and replaced it with a 3D printed bracked with an Arduino Nano mounted on it and the USB port accessible on the back of the meter. This project is great!
The 3D print file if anyone's interested: https://www.printables.com/model/1403032-arduino-nano-mount-for-hp-3478a-multimeter
Edit: Now that I said this, I actually tested it with the bracket installed, and it doesn't work... I get a serial connection but no response to GPIB commands or the SRQ key...  |O
« Last Edit: September 02, 2025, 07:31:21 pm by Vaionko »
Offline kuwoyuki
  • Country: cz
« Reply #277 on: December 08, 2025, 02:09:13 pm »
Here's my version on a WCH CH32V203. There's a demo video and a PCB link in the readme.
It's a bit simpler and I didn't implement a 2 button nav with "LOCAL", and just did a hover/timer menu instead since I think it's a bit hacky and couldn't get it to work reliably, maybe kirill_ka can explain how it's done?
