Author Topic: Prototyping in process...  (Read 3790 times)
Offline slateraptorTopic starter
« on: November 23, 2011, 08:29:09 am »
It's been an interesting learning experience thus far. Still have a bit to go; 95% code from this point forward.
All rails stable on load, FPGA boots and configures, VGA outputs.
When all is said and done, a complete redesign without haste and deadline is in order.
Offline BravoV
  • +++ ATH1
Re: Prototyping in process...
« Reply #1 on: November 23, 2011, 08:59:31 am »
Looks great, what does it do ?
« Reply #2 on: November 23, 2011, 09:14:48 am »
I thought the sockets were a dead giveaway. ;)
With a bit of VHDL savvy and a pinch of luck, a cycle-accurate NES emulator largely inspired by the work of Dan Strother and Brent Allen, and fueled by the countless others that have contributed reverse engineered data on nesdev.parodius.com/ throughout the years.
http://danstrother.com/fpga-nes/
The main difference is 1) all hardware was designed from the ground up, and 2) I'm working solo on this project with a tight deadline (everyone in my class either thought my project was lame or ran away screaming by the complexity when I proposed the project late August). :-\
Offline Balaur
« Reply #3 on: November 23, 2011, 09:42:04 am »
Hey, the famous sockets! I'm glad to see that you managed to fit them. Did you ground the pins or did you drill larger holes?
Nice project and kudos to you for your work ethic and enthusiasm.
Quite complete as well. I can see:
- discrete (i.e. not POL) switching supplies - not the easiest solution, but it shows your determination
- the FPGA with its oscillator, JTAG port and adequate decoupling
- 6 bits resistor ladder DACs for the VGA
- modular construction
- a LED on the FPGA board. Is that the DONE led?
Hey, show us the middle board too!
How is the sound generated?
Congratulations and many nice wishes for easy development and debugging!
Cheers,
Dan
Offline Balaur
« Reply #4 on: November 23, 2011, 09:45:16 am »
By the way, what's the Bluetooth for?
« Reply #5 on: November 23, 2011, 09:57:20 am »
http://upload.wikimedia.org/wikipedia/commons/1/1d/Wii_Remote_Plus.jpg
More details when time permits. I intend to publish all my work online NLT next summer.
