Hi
I decided to challenge myself and build a PSU for my own use, using only discrete components.
Vout = 0 ~10v
Imax = 2A
CV and CC control
The CV part is already well advanced, where I'm having good results in terms of stability and low noise. It remains to perform the transient test and thus be able to verify the phase margin.
My other challenge is with the CC control, which I want to place on the high side. I see many projects using dedicated Opamps and CI. Already using only transistors, the information is kind of scarce. I received a tip that I could use a current mirror, which would then be unbalanced by the sensor resistance. Does anyone have a tip or example circuit, on how I could design this CC control, only using discrete components? Going from 50mA to 2A
