I made an audio amp based on TSP's youtube video #23, but it won't put out the voltage I expect from it. I designed it for 4v pk-pk (i thought...), but it hardly gets to 2v pk-pk before flat-topping . It's a push-pull class B, 6v split supply driving an 8Ω speaker. Here is the schematic and this is what I did...
Step 1) The push-pull pair needs degeneration resistors, I went with 1Ω as I had them available. So that means each transistor will see a 9Ω load.
Step 2) Being I want 4v pk-pk (2v work from each transistor), 2v/9Ω=222mA should be the max current that each transistor will ever see (rms will be lower, but I am worried about calculating base current here).
Step 3) My transistor tester says these amazon "multi-pack" variety S8050 and S8550 transistors have beta of 200. So, that means the base current should be 222mA/200=1.1mA. But for the emitter follower driving the base to supply it, that transistor will also need some current, so I double it and say 2.2mA through those resistors. To have the push-pull pair biased for B, I need .7v on the top driver emitter and -.7v for the bottom driver's emitter.
Step 4) that means the emitter resistors will have 3v-.7v=2.3v across them when biased properly. And 2.3v/2.2mA=1045Ω. I went with 1kΩ.
Step 5) Biasing the drivers. I went with 10x the base current here, so, 2.2mA/200*10=.11mA and 6v/.00011A=54,545Ω total ~ I just call it 22KΩ for each resistor.
Step 6) If I were to input a signal here, it would see those two bias resistors in parallel, and to cut a few corners, lets call the impedance here 10kΩ.
Step 7) So, if I want to drive that with very little voltage drop, I need a 1kΩ source impedance or better... I also need voltage gain of 4 because my signal is 1v pk-pk and I want 4v pk-pk, so lets kill 2 problems with 1 transistor. Calling the collector resistor my output impedance (1k), that makes my emitter resistor 250Ω (for 4x gain). I used 220Ω as that's all I had.
Step
Biasing that bugger now... Again, with a beta of 200 and following the usual procedure (and assuming the collector is going to sit at about .35v to split the voltage available after the emitter resistor eats a little).... 3v-.35v=2.65v across the 1kΩ resistor for a collector current of 2.65mA. That means there is 2.65mA/200*10=.133mA through the bias network for that stage. And with 2.65mA also going through the 220Ω emitter resistor, I figure the base voltage will be around .00265A*220Ω=.583v at the emitter, so -3v + (.583v+.7v) = -1.283v at the base. So the bottom resistor will have 1.283v across it and the top resistor will have 4.717v across it. And since we know the current, 1.283v/.000133A=9,647Ω and 4.717v/.000133A=35,466Ω. And that 1.283v leaves plenty wiggle room for my .5v pk-pk input signal (I used 47k and 12k, close enough).
At this point, the input impedance is too low for my signal, but I tested the circuit anyhow using my signal generator (that can drive that easily without voltage drop), and for some reason, when I do, the signal looks great until it gets to the final stage where the output is clipping at just under 2v pk-pk. I was expecting just under 4v peak to peak. Did I do something wrong? Are these S8050 and S8550 amazon transistors junk? Thanks!
