Hello, sorry I’m advance if this is not the right section to post the question. I am looking to combine ntsc signals from at least 2-4 cameras, and have them combined/ superimposed together to have one output with low latency. Specifically, I am trying to combine 4 ntsc signals from 4 cameras with telephoto lenses, spaced out to have the right framing where the image borders intersect, and have a processor join these images together into a seemingly higher resolution image than just one camera has by itself.
My goal is to use 4 flir lepton sensors with ntsc output breakout boards, and have these ntsc analog outputs combined via some sort of microprocessor to have one low latency output that can be used to go to an analog video transmitter. Thank you in advance.
