Author Topic: Question about an SMD capacitor.  (Read 10747 times)
Offline CarringtonTopic starter
« on: April 13, 2014, 08:40:02 pm »
Hi guys!
Anybody know:
Who is the manufacturer of this capacitor?
And what type of capacitor is?
Thanks.
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline 8086
    • Circuitology - Electronics Assembly
Re: Question about an SMD capacitor.
« Reply #1 on: April 13, 2014, 08:41:32 pm »
No, and no.
Your best bet is to measure it with an ESR meter and find an equivalent.
« Reply #2 on: April 13, 2014, 09:19:42 pm »
No, and no.
No no no...  :-DD
I'm sorry, but I need to know the manufacturer and the type.
« Last Edit: April 13, 2014, 09:22:11 pm by Carrington »
Space Weather.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: April 13, 2014, 09:25:46 pm »
Kemet 3900pF.  Package size, voltage and material/tempco unknown (although it obviously isn't one of the types printing is not available on).
page 504 http://www.kemet.com/Lists/ProductCatalog/Attachments/364/KEM_CC101_COMM_SMD.pdf
Seven Transistor Labs, LLC
« Reply #4 on: April 13, 2014, 09:36:42 pm »
Yes, exactly, it matches. My LCR measured 3.83 nF.
Thank you very much.  :-+
Laser marking option is not available on:
• C0G, Ultra Stable X8R and Y5V dielectric devices
• EIA 0402 case size devices
• EIA 0603 case size devices with Flexible Termination option.
• KPS Commercial and Automotive Grade stacked devices.
So probably is an X7R.
« Last Edit: April 13, 2014, 09:49:22 pm by Carrington »
Space Weather.
Offline tszaboo
« Reply #5 on: April 13, 2014, 10:24:31 pm »
wow, that smd ceramic capacitor actually has a marking... I think it is one of the rarest thing in the world.
Offline 8086
« Reply #6 on: April 13, 2014, 10:33:28 pm »
Oops, I meant LCR meter earlier, not ESR meter...
I'm amazed it was identified, good job.
Offline c4757p
  • adieu
« Reply #7 on: April 13, 2014, 11:10:19 pm »
Now if only they thought to mark it "3n9" or "392"... ::)
« Reply #8 on: April 13, 2014, 11:14:00 pm »
Don't worry, we're human.  :)
Space Weather.
« Reply #9 on: April 13, 2014, 11:16:09 pm »
Yes is true, is not very common.
Space Weather.
« Reply #10 on: April 13, 2014, 11:24:50 pm »
No idea of how they choose marking codes, but not much space to write, the small case is a 805 (I need a microscope to read them):
  - KS3   4.7nF, read 4.69nF.
  - KW2 680pF, read 686pF.
  - KA2  100pF, read 101pF.
« Last Edit: April 13, 2014, 11:28:23 pm by Carrington »
Space Weather.
Offline Richard Head
« Reply #11 on: April 14, 2014, 08:21:44 am »
That colour (light grey) dielectric is usually NPO or COG. The brown colour is normally X7R.
I'm sure it's NPO/COG for that reason.
« Reply #12 on: April 14, 2014, 12:02:28 pm »
Probably you're right, that's what I thought initially, but according to the datasheet: "Laser marking option is not available on: C0G, Ultra Stable X8R, ...".
However, at the moment I prefer to believe that they are COG/NPO. I discard polyphenylene sulfide (PPS). It's rare, right?
Dielectric Material PPS: http://www.hitachiaic.com/products/plastic_film_chip_capacitors
Tª Coefficient X7R: http://www.digikey.es/product-detail/en/C1206C392K5RACTU/399-1229-2-ND/411228 (Brown colour)
« Last Edit: April 14, 2014, 12:05:31 pm by Carrington »
Space Weather.
Offline DmitryL
« Reply #13 on: April 14, 2014, 12:59:45 pm »
If you have an access to more or less decent LCR meter, you can easily distinguish between NP0 and X7R types of ceramic capacitors. NP0 ones have Q around 1000 or more, when X5R and worse types have Q around 100. I have seen NP0 capacitors that have the same brown color as X7R, though they tend to be white grey or pinkish
« Reply #14 on: April 14, 2014, 01:22:54 pm »
A DER EE DE-5000 read a Q between 800 and 1800, nothing close to 100. So definitely are NP0.  :-+
Moreover, the Q factor estimation by a DE-5000 is very unstable.
« Last Edit: April 14, 2014, 01:43:29 pm by Carrington »
Space Weather.
Offline T3sl4co1l
« Reply #15 on: April 15, 2014, 01:35:45 am »
Perform the measurement at high temperature.  Anything other than C0G will be down by 20% or more at 100C+.
Offline electron_misfire
« Reply #16 on: April 15, 2014, 08:02:36 am »
It's quite annoying when working with SMD capacitors when they don't have a single mark on them.  |O
« Last Edit: April 15, 2014, 08:07:06 am by electron_misfire »
« Reply #17 on: April 15, 2014, 07:55:56 pm »
That is a good reason to have a LCR meter though, to not have to play the guessing game too much.
Offline Aigars
  • Country: is
  • elerepair
