1 MV isn't going to happen on an AC power line, but just for grins, let's assume 500 kV.
What are you talking about?!
We are talking about AC transmission lines.
You said 1kV AC is “not gonna happen”. Well it can happen, and is in fact in use.
Not DC.
Did you even read my entire post before barking back? It is 1000% clear that I know that, since I explicitly mention 1MV AC lines and contrast with DC ones, too.
The highest voltage in use in the USA is 765 kV. In other parts of the world, AC transmission lines operating at voltages 1 MV and above are rare and unusual to the point of being a special talking point.
So? The fact is, you said 1MV AC can’t be done, but it can. The same laws of physics apply everywhere. The fact that it isn’t done commonly, or that it isn’t in use in USA, does not change the fact that 1MV AC is doable, and not just in theory, but in practice.
P.S. “What are you talking about?” is also an expression meaning as much as “where’d you get that incorrect idea?” When, like here, the rest of the response clearly indicates that the person knows the topic of discussion, you should know that it isn’t a query meaning “please name the topic of discussion”.
