I am looking for feedback on whether or not this circuit will work.
I am considering purchasing a peltier based cooling module (
https://www.amazon.com/gp/product/B07HCBMJM4) that will be used to keep a cabinet at relatively consistent temp (86 degrees F). I live in a desert and sometimes the temps can vary widely on either side of the target and the cabinet will be in a garage. The idea here is that if the temp needs to be brought down to target, I would run the cooler so that the heat sinks inside the cabinet run cool to bring the cabinet to the target temp. However, if the temp inside the cabinet is too cool, then I would reverse polarity on the cooling chips so that heat would be used to bring the inside temp up to the target temp. There will be a larger fan inside the cabinet to circulate air throughout the cabinet and it will be blowing directly over the smaller heat sinks from this device.
Here is the schematic I came up with to allow me to switch polarity on the peltier devices.
I wil use a microcontroller to handle the switching.
All MOSFETs will have a 1k resistor at the gate (removed from schematic for simplicity)
The arrows indicate the direction of current flow.
P21 will be brought low, followed by a delay, then P20 will go high. This will activate cooling.
P20 will be brought low, followed by a delay, then P21 will go high. This will activate heating.
If either P20 or P21 is high, P22 will also be high, which keeps the fans running on the heat sinks and they always run in the same direction (moving air onto the heat sinks).
The MOSFETs are all logic level MOSFETs and are rated to handle more than 4 times the amount of current that the peltiers will use.
Will this circuit work?
