Author Topic: R485 communication? Ground?  (Read 1779 times)
Offline viperTopic starter
« on: October 03, 2026, 12:38:15 am »
Since my last thread went nowhere, I will slim this down.  Does having a ground wire connected between a 485 to USB adapter matter?  Im using Qmodmaster trying to poll for any response at all. Nothing with 2 wires and countless setting changes.  I have another RS485 module on the same device that seems to communicate without need for the ground.
Offline Doctorandus_P
Re: R485 communication? Ground?
« Reply #1 on: October 03, 2026, 01:12:57 am »
Yes, ground matters. RS485 has a common mode range between -7 and +12V, and without the GND wire, the leveling has to be done with the data lines, and that adds distortion.
Opto isolated RS385 transceivers often (seem to) "work" without the GND wire, but you're still eating into the margins.
Sometimes the GND wire is handled in another way, for example via the mains earth wire
« Reply #2 on: October 03, 2026, 01:43:40 am »
Thanks!  This is where I am, right or wrong.  It is said I need to see about 200mv of A-B separation.  I tested at 80mv.  The little dongle that will certainly work in that db9 port I measured 2kohms resistance between the gnd and B, then .24Mohms between gnd and A.  I also checked my adapter and see 4ohms gnd to B and 24kohms between gnd and A.  So it seems connecting the gnd will give the reference and a proper pull down on B?  Prob snub some noise too?
Offline KrudyZ
« Reply #3 on: October 03, 2026, 02:25:43 am »
RS485 is bi-directional.
You will only see valid signals if one side is transmitting...
Offline uer166
« Reply #4 on: October 03, 2026, 03:01:38 am »
Yes, it matters, for similar reasons why USB needs a GND as well, and other pseudo differential buses like CAN.
« Reply #5 on: October 03, 2026, 05:22:30 am »
I might have realized I F'd up......  Stumbled into a vid that says that Qmodmaster has a quirk where you write the start address 1 number higher than desired.  Duh.....  I noticed to started at 1 and I had to go into settings to get it changed to a zero, in which who knows what register that is trying to poll but there ain't a 99 or 999.  Hopefully that will bring some action tomorrow.  What else did I miss.......lol
Offline 5U4GB
« Reply #6 on: October 03, 2026, 05:33:10 am »
I think there's two answers here, a ground is a good idea with RS485 in general but in your case if you're seeing absolutely nothing then I think there's a bigger problem than a lack of ground.
For the wiring I've done at home, all optoisolated RS485, I don't use a ground because it's running to locations that may have a different idea of what ground is, and have never had any problems. I know this isn't good practice but just pointing out that your problem probably isn't lack of ground.
Offline 5U4GB
« Reply #7 on: October 03, 2026, 05:36:40 am »
That's not a quirk, if you're using modbus then some things start the register count at 0 and some at 1.
For testing modbus comms, get some cheap modbus devices with known characteristics and stick that at the other end of the link.  I use a $5 4-digit LED display off Aliexpress, it both has fixed, known registers and I can see the effect of any commands immediately, no need to faff around with modbus emulators that don't quite behave as expected.
Offline PGPG
« Reply #8 on: October 03, 2026, 01:26:33 pm »
It doesn't matter in a sense 485 works or not during your experiments.
It matters in a sense of emitted disturbances and being sensitive to strong external disturbances.
For optoisolated RS485 I understand the GND connection between them as connecting insulated side GNDs and not what you can have the idea as device ground.
In my opinion....
In optoisolated RS485 you have 2 disturbance sources:
- DCDC converter supplying insulated RS485 driver,
- RS485 driver itself.
When I used DCDC with 4kV trafo with very small capacitance (4.2pF) the DCDC disturbances and disturbances generated by RS485 driver (with about 250kbps limited bandwidth) are effectively suppressed by these small capacitance inserted in ground-loop so practically adding GND connection between RS485 drivers have no effect.
When I used just standard DCDC that needed be blocked by 1nF to limit its emissions at insulated GND side than I lost the suppressing action of 4pF for driver generated disturbances. The disturbance generated by driver (mainly because one line changes voltage little before the other generating common mode pulses) are now traveling in a loop through these 1nF. Adding GND connection (not devices GND but insulated RS485 drivers GND) gives to these disturbances the short way back along the A,B wires making the loop emitting them as small as possible.
The same way you can look at sensitivity to external disturbances. Having two 4pF in series in loop limits their current (flowing through A,B) much better than having there 1nF. When (thanks to 1nF) currents are bigger adding GND connection between insulated RS485 drivers makes these current be flowing through this GND connection making their effect on your A,B signals weaker.
« Last Edit: October 03, 2026, 01:28:43 pm by PGPG »
Offline uer166
« Reply #9 on: October 03, 2026, 08:26:10 pm »
Its still a great idea to connect the GNDs of the isolated transceivers together to attenuate common mode disturbances with ~zero ohms instead of whatever CM impedance the transceivers present at various times in the communication cycle..
« Reply #10 on: October 04, 2026, 05:45:53 am »
Wasted some hours of my life today......lol  So I ended up putting vampire/sniffer wires on the wifi dongle for this 485 port to learn something.  Used Yat to listen, and it spits out a string of ascii at first boot.  Several parameters like voltage, frequency, etc, then goes quiet.  What I am reading on is possibly that my setup is not pulling signal hard enough on tx. I don't know yet but the converter with no wires is 4.3V from A-B with a internal resistor of 4k gnd-B.  When connected to machine, that line drops to 85mv and seems to stay around there when transmitting, but Im just using a dmm for now.  I know that ascii string coming out brings more than 300mv swings though.  Some info suggests adding stronger pull up/downs on the converter.  I guess since I have the sniffer wires on the dongle, I can do some more studying there before I commit.
Offline Perkele
  • Country: ie
« Reply #11 on: October 07, 2026, 09:12:32 pm »
Depends.
In some of cases it's perfectly doable, in some just don't waste time and add the ground wire.
Cable Length?
Baud rate?
Number of other RS-485 nodes on the line?
