Author Topic: radiated emissions inside power supply effecting microcontroller?  (Read 3292 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: September 27, 2014, 05:20:11 am »
Can I put a MCU on the same board as a switchmode power supply? It is galvanically/optically isolated on its own ground plane. The MCU is 3 inches away from any mains connections, which is switching 5A@110V@10KHz. The gap between the two ground planes is ~0.3 inches.
Should I put the option for a shield can around the mains SMPSU? There is no analog stuff that is exposed to anything, just a MCU/RS232 interface.
Could a shield like this possibly be effective?
*star washer under screw
« Last Edit: September 27, 2014, 05:34:45 am by SArepairman »
Offline Rerouter
Re: radiated emissions inside power supply effecting microcontroller?
« Reply #1 on: September 27, 2014, 06:47:13 am »
there should only be 2 cases where a micro can be upset inside a noisy enviroment, the first is noise coupling through long or high impedance traces, the second is its supply rails / reset line, follow good decoupling practices on the supply rails, and add a pull up or pull down resistance on every pin that is not being driven hard, to ensure that both noise cant cause a glitch and secondly positive or negative going spikes have somewhere to go if coupled that strongly,
« Reply #2 on: September 27, 2014, 06:55:02 pm »
If there is a long trace between two devices (such as a RS232 chip) should I distribute the pull down resistor between the two chips b/c of the trace inductance (5 inches )?
Would the shield that I described get rid of a need for the extra pulldown?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: September 27, 2014, 11:21:30 pm »
I don't see how there'll be enough noise to cause problems at pretty much any distance... it's just logic...
Seven Transistor Labs, LLC
Offline T3sl4co1l
« Reply #4 on: September 27, 2014, 11:22:31 pm »
Pulldowns have very little effect on signal quality.  You need resistors on the order of Z_0 to do that.  Typical trace impedances are around 100 ohms.
Offline poorchava
  • Troll Cave Electronics!
« Reply #5 on: September 29, 2014, 07:36:39 pm »
10kHz seems way low for a mains psu. It's gonna emit audible noise. Why don't you move the frequency to somewhere around 30kHz?
« Reply #6 on: September 30, 2014, 02:41:40 am »
as the pic programs it I can put a time delay on it, so it fools the customer into thinking that it is quiet and then wham bam 5KHz switching :-DD
i wonder if its possible to play music with a switcher, or even speech...
« Last Edit: September 30, 2014, 02:44:09 am by SArepairman »
