Author Topic: Radio Direction Finding  (Read 162065 times)
Offline katzohki
    • My Blog
Re: Radio Direction Finding
« Reply #125 on: September 29, 2014, 06:50:09 pm »
Wow, really cool!
Offline PA3BNXTopic starter
  • Trying to learn better programming and designing !
« Reply #126 on: October 15, 2014, 06:53:30 pm »
Hello Everybody,
I have the new updated version SoundDoppler146All on our PI4WAG site.
It has now switchable driver  8, 12 or 16 bits SoundCard inputs
Improved Noise Squelch
And Fieldlogger102 that is a GPS-RSSI FT817 FT840 logging program.
The log files can be played in MyMapping.exe
So have fun !
Greetings,
Lodewijk
Credo:
Home brew projects:
Build/Design  with minimum hardware
and maximal software.
« Reply #127 on: October 19, 2014, 05:14:49 pm »
Hello Every Body,
New Idea!
5x Antenna SuperSimpleSoundDoppler VHF/UHF
My wish is an optimal doppler system for VHF/UHF
without the need to change the antenna array.
Normally you have to exchange the whips and change the antenna
circle width.
I propose to  create a VHF/UHF antenna by switching the length
of the antenna.
The diameter of the antenna circle must be as large as possible
for the highest frequency.
By giving the antenna the length of 17 and 50 cm.
For that is needed a re-tour conductor so a monopole
that consist off two parallel conductors.
The switches are ordinary 1n4148 diodes.
Maybe it can be build by twisting wires in a
standard PVC electricity tube.
(No idea of a twisted isolated wire functions as stiff antenna in this
construction method)
The antenna plug must consist of two contacts that cannot be turned around
5x monopole antennas instead of 4 because bigger capture area but also
for VHF a bigger base width.
(By adjacent monopoles may by 430 MHz maximal 17 cm)
So more monopoles means bigger circle diameter possible.
See also my SoundDoppler program the 'Doppler antenna array calculator'
5 antenna maybe possible without to complicated control cable.
The control cable needs 5 antenna control  lines a VHF/UHF line and mass
There are 7 pin Din connectors but also of course cheap db9.
The antenna plate must be for 430 MHz about 60 cm diameter and the antenna
circle diameter about 26 cm.
that gives with 600 Hz Doppler about 2.8 kHz bandwidth.
Same measures for VHF 145 MHz about 1.7 kHz bandwidth.
Only needed an extra switch to serve for antenna VHF or UHF.
Remark:
If you take a bearing on VHF and the station becomes very strong
you can attenuate by switching to UHF so to short and attenuates.
Why not us a dual band VHF/UHF antenna
because on UHF a VHF/UHF antenna resonates
and with the doppler you don't want to disturb RF field
by absorption or reflection.
The coax cables do still need good earth at each antenna feet.
5x big magnet glue feet with much capacity between
feet and car roof is possible wit feet that have space for the components.
I am curious to see the performance of an antenna-array with antenna at 5 x 72 degrees angles
and if this differences with errors at 4 x 90 degrees angles
73's
PA3BNX
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #128 on: November 25, 2014, 09:12:41 pm »
Hello Everybody,
I did build a small audio pre-amp with galvanic separation transformers
for connecting de Doppler hardware to the soundcard of the PC.
So enjoy !
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #129 on: December 13, 2014, 08:38:26 pm »
Hello Every Body,
New version SoundDoppler148All.zip on the site PI4WAG
ManualSend Button option.
en bugs fixed in logging all the audio wav files in 8 bits 8000 samples/sec PCM
http://www.pi4wag.nl/projecten/doppler-peiler-radio-direction-finder
73's
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #130 on: December 21, 2014, 05:19:49 pm »
19-12-2014
21-12-2014
Subject Corner-reflector antenna
I want to easy transform the 4x doppler antenna array
to a amplitude direction finder (Watson Watt)
By adding just a crossed screen in centre of the 4
antenna array it would become 4 corner reflector antenna
If I made that of cardboard with hinges with ALU foil glued on it
it just can place or remove it
Than I have to switch the RX from FM to AM
and I am done !
I think the 4 corner antenna have higher gain
and is more suited for pulse detection then doppler
detection.
(When manually used with a switch box that can
switch each antenna separate on you could use this also for DF chasing
with just a receiver with s - meter and no need for a yagi turn-able
on roof of car)
I think it catches a lot of air pressure in a driving car but could be
used when not driving or stationary application.
Place a screen between the 4 monopoles or dipoles
from a standard SuperSimpleSoundDoppler antenna array
to transform it to a Am direction finder with correlation detector
and more gain and better pulse detection
Receiver mode changed from FM to  AM
Curved reflector increases the gain (But more difficult to construct)
Some expected performance details
F/B value 20 - 35 dB ?
Gain maximal 7 dB with 1/2 lambda driven element
angle usually 90 degrees
S = distance corner to radiator
w = width about 2x lambda radiator
T = screen length one site 1/2 lambda more then S
Feed point impedance versus distance to corner
Do not
With a distance S = 0.5 lambda gives 2 main directions
Bigger distance then 0.65 to .85 lambda okay about 5 dB gain
Any one with more info let me now !!
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #131 on: December 21, 2014, 05:37:49 pm »
You probably could use a simple GRP cylinder to enclose the 4 reflectors and elements to make an antenna that would be more aerodynamic, though of course using a higher frequency would make it smaller as well, but then limit your range considerably.
You probably could use 2 frequencies, with a lower one giving the range and the higher one for localising. You could make it more difficult using a different repetition rate on the 2 transmitters though, with the localiser chirping more often, but the lower repetition rate of the high frequency one ensuring you have more difficulty in locating the fox. you could even separate the 2 transmitters, and have a 2 part hunt by having the second one a preset distance known beforehand ( within a rough area) from the localising transmitter.
« Reply #132 on: February 14, 2015, 03:15:00 pm »
Hello Every Body,
I did made a prototype for AM VHF/UHF RDF with 4060 and tl072 (No voltage regulator needed)
And a picture of the cross screen placed between a standard pseudo doppler antenna array.
« Last Edit: February 18, 2015, 05:56:22 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
Offline EA4FRD
« Reply #133 on: February 15, 2015, 12:33:42 pm »
Dear All,
I keep trying to build a ARDF system for T-hunting (by car) in 27MHz (CB). I built sometime ago a system based on magnetic antennas (90 cm separation on the roof), IC switcher and PA3BNX software but not to much sucess.
I should keep working in that but maybe you guys know any other better system for CB. I shown the PA3BNX for HF suggested with loops, but I would need more information about plans and distances.
Thanks sincerely in advance.
Carlos.
« Reply #134 on: February 18, 2015, 06:04:28 pm »
Hello EveryBody,
I send to pictures for  direction find loops.
See also pictures on this site.  11 meter loop
http://verbed.home.xs4all.nl/hamspace/pe5edw/11m_peilantenne/11m_peilantenne.htm
You Tube Sokol dl1roj
Ahha doppler demo KD6IRE AI6RE
... detailpage
73's
Greetings,
Lodewijk
Credo:
Home brew projects:
Offline EA4FRD
« Reply #135 on: February 18, 2015, 07:51:01 pm »
Dear PA3BNX,
Thanks for your photos and information. In case I decided to use the loop antennas what electronic should I use too? Should I use your software too?
Thanks again.
Best regards.
Carlos.
« Reply #136 on: February 22, 2015, 03:53:55 pm »
Hello Everybody,
Q Codes that can be used with fox hunting I think.
For 27MC you create a ring of 50cm with 10mm tube or outer shield of rg213 with two cuts opposite each other.
One end you connect to the the coax to rx and the other cut you put a resistor of about 330 Ohm.
If you use copper wire for the ring of 2.5mm2 then better use 470 ohm.
There is one sharp minimum in the direction of the resistor. The other site gives one maximum.
Use good shielded coax. Remember the antenna does not have much gain but is quite uni-directional
I would make a 1:5 HF transformer that also is galvanic separated for the coax to match all.
See US2247743 for patent info.
See example R&S eb100
You can use my SoundDoppler software with the Aperiodic Cross loop + sens antenne circuit if you want
to hunt sofisticated hi...
Happy experimenting
Agilent TDOA around London Demonstration.
« Last Edit: March 15, 2015, 06:13:45 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
Offline oe6rke
« Reply #137 on: March 08, 2015, 10:45:00 pm »
Dear PA3BNX,
can you please lower the reference inital frequency border from 200 to 100 Hz? I rebuild the DO2SFD attiny board and noticed that the sine frequency is about 134 Hz.
Would be a great help if you can apply this Change.
thanks for the great Software,br Robert
« Reply #138 on: March 15, 2015, 06:02:20 pm »
Hello EveryBody
I ran over this site very nice high tech Yagi thunts.
I am working now on MyMapping 1.52
Witch will have a manual bearing input screen.
Okay in the next version the lower frequency of the referency range wil be lowerd to 100 Hz..
This might also be a nice cheap easy TDOA for 27 MHz Hunters.
http://www.fewo-line.de/dl4lbd/DUO1_W20.htm
« Last Edit: March 15, 2015, 06:09:14 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #139 on: April 07, 2015, 06:52:40 pm »
Hello Every Body,
There is a new version SoundDoppler149cAll.zip on the PI4WAG site now
That has a new MyMapping 1.53 in it
It has a Opacity pelorus and some very nice manual input futures...
The Agrelo GPS input through Comport has lots of improvement's
It should work quite okay now with
PicoDopp and VE2EMM and VRZA 2011 dopplers
We are working on a new doppler on a arduino board based platform
What also spit out Agrelo Formats'
Agrelo is the format to transfer Doppler data over RS232 / USB
Like %xxx/q<cr>< lf>
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #140 on: April 11, 2015, 07:45:29 pm »
Hello Every Body,
We are working on new Arduino Dopplers
To see our progress look at this
Dutch Forum
http://www.zendamateur.com/viewtopic.php?f=11&t=7271&start=480
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #141 on: April 17, 2015, 01:30:58 pm »
Hello Every Body,
I am trying to build a Arduino Uno R3 based Doppler
that connects through USB to the PC and MyMapping.exe program.
So see the shield and my initial improved sketch
I updated the sketch and added a shield picture. ToDay 24-05-2015
Again updated the Sketch 01-05-2015
Fixed several issues
Still working on the code
  ((C))PA3BNX
  Trying to create a SuperSimpleArduinoDoppler on Arduino Uno R3
  For this there is a special Arduino Com/USB input in MyMapping to show the headings on maps
  @12-04-2015
  @13-04-2015
  @15-04-2015
  @17-04-2015
  @22-04-2015
  @24-04-2015
  @25-04-2015
  @26-04-2015
  @27-04-2015
  @29-04-2015
  @01-05-2015
  Not ready yet!
  Try  max232 for Am WhatsonWatt DF to
  Need extra pin for that or use antPin ?
  Arrays are zero based !!!!
  Explaining Arduino pins.
  antPins[] Connect to antenna switcher pins
  refpa3bnx Connect to audio lowpass filter for soundcard referency input
  kPins[] Connect to kwadrant C's 4u7
  kPins[12] Connect to discharge transistor //Not yet done in hardware
  kPinAnalogue Connect to sum point of 4 cap's
//Byte= 0>255
//Int=  -32768>32767
 //String Serial params
 String inputString = "";             //Received serial string
 //Boolean
 boolean bStringComplete = false;     //Complete '\n' rxed serial string
 boolean bNoSetKpins = false;         //Do not change kPin[] because I am reading/empty them now
 boolean bMultiPathAverage = false;   //Multipath heading found in received headings from Averaged
//Const Integer
//Must be modified to right pin number arduino and arduino shield harddware
//Antenna Control Pins & refpa3bnx //Never use pins 0 and 1 because the UART must also function
//So I started with pin 2 to
byte antPin[4] = {2,3,4,5};           //Set antenna control pins (Not const because it can CCW/CW)
byte max232Pin[2] = {7,8};            //Set Max232Pin vor AM plate antenna
const byte refpa3bnx = 6;             //Pin for Referency frequency output to soundcard
//Kwadrant Capicity switches & analogue SCF read pin
const byte kPin[5] = {9,10,11,12,13};  //4 pins caps 4u7 Last Pin in array = Discharge caps by bc547
const byte kPinAnalog = A0;            //A0 read voltage across one 4u7 cap pin A0 to A5
const int cOffset = 511;              // .5 * 1023 caps offset
//Squelch Signals
const byte cSqlclosed = 0;
const byte cSqlclosed2open = 1;
const byte cSqlopen2closed = 2;
const byte cSqloverflow = 3;          //Capicitors are full
//NoDegreesMaxMinValues
const int cNodegrees = 999;           //Squelch No Signal or cSqlopen2closed
const int cMaxTime = 30;              //15 Sec/cMainLoopDelay Max time
const int cMainLoopDelay = 500;       //How fast the main loop runs in mSec
const int cMinAudioAmplitude = 100;   //There is enough signal to SinCosDetect
//Float const
//const float pi = 4 * atan(1);         //PI 3.14159
//const float rad = pi/180;
const float rad1 = 180/PI;              //57.295827
//const float TwoPi = 2 * pi;           //TWO_PI
//Integer
//Array with the 4 kwandrant analogue cap tensions These can be -511 to +511
int Cap[4] = {0,0,0,0};
int Calibrate= 0;                    //degrees default
byte sqlstatus = cSqlclosed;
//------------ISR Main Interrupt //This runs always--------------------
ISR(TIMER0_COMPA_vect)
 static byte c;
 //Do the Ant and Cap rotation here
 if (c==4){
  c=0;
 SetAntPins(c);
 SetMax232Pins(c);
 SetKpinsHigh;
 c++;
//---------Functions now-------------------
//Max232Pins for AM Whatson Watt RDF
void SetMax232Pins(byte t){
  switch (t){
  case 0:
   digitalWrite(max232Pin[0],HIGH);
   digitalWrite(max232Pin[1],LOW);
   break;
  case 1:
   digitalWrite(max232Pin[1],HIGH);
   break;
  case 2:
   digitalWrite(max232Pin[0],LOW);
   break;
  case 3:
   break;
//Antenna Control Lines Just counts 1234 1234 etc
void SetAntPins(byte t){
 switch (t){
  case 0:
  digitalWrite(antPin[0], HIGH);
  digitalWrite(antPin[3], LOW);
  digitalWrite(refpa3bnx,HIGH);
  break;
 case 1:
  digitalWrite(antPin[1], HIGH);
  digitalWrite(antPin[0], LOW);
  break;
 case 2:
  digitalWrite(antPin[2], HIGH);
  digitalWrite(antPin[1], LOW);
  digitalWrite(refpa3bnx,LOW);
  break;
 case 3:
  digitalWrite(antPin[3], HIGH);
  digitalWrite(antPin[2], LOW);
  break;
//Set kwadrant Cap Pins just High
void SetKpinsHigh(){
  if (bNoSetKpins==false){
   //Set all HIGH
   for (int i=0 ;i<4;i++){
      digitalWrite(kPin[i],HIGH);
//Get the 4 analogue value's in Cap[]
void GetCapValues(){
  //All kwadrant Cap Pins HIGH
  for (byte i=0; i<4; i++)
  //Read them one by one
  digitalWrite(kPin[0],LOW);
  Cap[0]  = analogRead(kPinAnalog)-cOffset;
  digitalWrite(kPin[0],HIGH);
  digitalWrite(kPin[1],LOW);
  Cap[1]  = analogRead(kPinAnalog)-cOffset;
  digitalWrite(kPin[1],HIGH);
  digitalWrite(kPin[2],LOW);
  Cap[2]  = analogRead(kPinAnalog)-cOffset;
  digitalWrite(kPin[2],HIGH);
  digitalWrite(kPin[3],LOW);
  Cap[3] = analogRead(kPinAnalog)-cOffset;
  digitalWrite(kPin[3],HIGH);
//Empty the 4 capicitors by discharging to 1/2 U
void EmptyCaps(){
  pinMode(kPin[i],LOW);
 digitalWrite(kPin[5],HIGH); //Discharge cap pin bc547
 delay(2100); //Let the 4 caps charge to 1/2 U  to 99%  5 * (22k * (4,7uF * 4))  2068 Sec
 digitalWrite(kPin[5],LOW);
//-------------Squelch-----------------------
int Squelch(){
//Return the sqlstatus
//Try Find a full cap
 int x;
 //Find cap with highest voltage/tension
 //Biggest value = cOffset (511)
 for(byte i=0; i<4; i++)
  if abs((Cap[i]) >= cOffset )
   x = abs(Cap[i]);
 //See if there is a Full Cap
 //cOffset = Biggest value
 if (x >= cOffset)
  return cSqloverflow;
 //Caps are full so need discharged
 else if (x >= cMinAudioAmplitude)
  return cSqlclosed2open;
 else if (x < cMinAudioAmplitude)
  return cSqlclosed;
//Detect Multipath in SCF Caps
boolean MultiPathDetectSCF(){
//Calc average of 4 kwadrants
//If to large asymetric value return true
//Can it do also the Quality 1-9 ?
int x;
for (int i=0 ; i<4 ; i++){
  x += Cap[i];
//150 of max 510 is the MultiPath level ?
if (abs(x) > 150){
return true;
else
return false;
//Calibrate
int Cali(int degrees){
 return LimitDegrees360(degrees(Calibrate + degrees));
//Return Agrelo formatted string % and 3 digits always
  String Format3Degrees(int degrees){
  String str;
  int digits[3];
  int reminder;
  digits[0]=degrees/100;
  reminder = degrees % 100;
  digits[1]= reminder/10;
  reminder = reminder % 10;
  digits[2]=reminder;
  str += '%';
  str += digits[0];
  str += digits[1];
  str += digits[2];
  return str;
//Limit Degrees 0 to 360 degrees
int LimitDegrees360(int d){
  //Limit degrees 0 to 360 here
if (d >= 360){
  return d - 360;
  else if (d < 360)
  return d;
  else if (d < 0)
  return 360 + d;
  else
  return cNodegrees;
//Average
int Average(int d){
  //If d = 999 (cNoDegrees) then reset average
  //Else return averaged degrees
  //Integer
  static int sum[4];     //Sum of counts for each kwadrant
  static int c[4];       //Cap tension/voltage in 4 kwadrant
  int xx[4] ={0,0,0,0};  //Adjacent kwadrants
  int z = 0;             //Most adjacent headings
  int z1 = 0;            //Other two kwandants headings
  int y = 0;             //Index where the most headings are
  int avDegrees;         //Averaged degrees
 //Limit amount off averaged headings
 if  (c[0]+c[1]+c[2]+c[3] > cMaxTime ){
  for (byte i=0; i<4 ; i++){
   sum[i]=0;
   c[i]=0;
  return cNodegrees;
  if (d!=cNodegrees){
  if (d >= 0 && d < 90){
  sum[0] += d;
  c[0]++;
  if (d >= 90 && d < 180){
   sum[1] += d;
   c[1]++;
  if (d >= 180 && d < 270){
  sum[2] += d;
  c[2]++;
  if (d >= 270 && d <= 360){
  sum[3] += d;
  c[3]++;
 else
 //Reset
  for (byte i=0; i<4; i++){
  sum[i]=0;
  c[i]=0;
 return cNodegrees;
  //Find 2 adjacent kwadrants with hold most counts
  //Count all adjacents kwadrants
  xx[1] = c[0]+c[1];
  xx[2] = c[1]+c[2];
  xx[3] = c[2]+c[3];
  xx[4] = c[3]+c[0];
  //Find out in witch two kwadrants the most headings are
    if (xx[i] >= z){
    z = xx[i]; //Most Headings
    y = i;     //Witch 2 adjacent Array Index
//Check for multipath
switch(z){
case 0:
 z1 = 3;
 break;
case 1:
 z1 = 4;
 break;
case 2:
 z1 = 1;
 break;
case 3:
 z1 = 2;
 break;
if (z > z1){
bMultiPathAverage = true;
else
 //Average the 2 most counts kwadrants
switch(y){
case  1:
 avDegrees = (sum[0] + sum[1]) / c[y];
 break;
case 2:
 avDegrees = (sum[1] + sum[2]) / c[y];
 break;
case 3:
 avDegrees = (sum[2] + sum[3]) / c[y];
 break;
case 4:
 if (c[3] == 0 && c[0] > 0){
 avDegrees = sum[0] / c[0];
 break;
 if (c[3] > 0 && c[0] == 0){
 avDegrees = sum[3] / c[3];
 break;
 if (c[3] > 0 && c[0] > 0 ){
 avDegrees = LimitDegrees360(((sum[3] / c[3]) + ((sum[0] / c[0]) + 360) / 2));
 break;
if (d == cNodegrees){
  return avDegrees;
//SinCosDetector Find the degrees from the 4 Cap[] tensions
int SinCosDetector(){
  int SinSum;
  int CosSum;
  int x;
//In Cap[] is the tension value of 1 of the 4 C'S
SinSum = Cap[0] - Cap[2];
CosSum = Cap[1] - Cap[3];
if (SinSum == 0 && CosSum == 0){
 return cNodegrees;
else
 return LimitDegrees360(atan2(SinSum,CosSum) * rad1);
//=============SerialRx Event===========================
void serialEvent() {
  while (Serial.available()) {
    // get the new byte:
    char inChar = (char)Serial.read();
    // add it to the inputString:
    inputString += inChar;
    // if the incoming character is a newline, set a flag
    // so the main loop can do something about it:
    if (inChar == '\n') {
      bStringComplete = true;
     else
//------------------------------------Main Functions-----------------------------------------
//SetUp
void setup()
  // Loop over the pin array and set them all to output:
   Serial.begin(9600); // Opens serial port, sets data rate to 9600 bps
   Serial.println("((C))PA3BNX Arduino Doppler");
   Serial.println("%999"); //Squelch always closed at start
   pinMode(refpa3bnx,OUTPUT);
   pinMode( kPinAnalog,INPUT); //Okay here ????
   pinMode(kPin[5],OUTPUT);    //Discharge Pin bc547
   pinMode(max232Pin[0],OUTPUT);
   pinMode(max232Pin[1],OUTPUT);
     pinMode(kPin[i],OUTPUT);
     pinMode(antPin[i] ,OUTPUT);
     digitalWrite(antPin[i],LOW); //antPin LOW
     digitalWrite(kPin[i],LOW);  //Set Cap pins to low so the can charge to 1/2U
   Average(cNodegrees); //Reset all to 0
   EmptyCaps;           //All kPins to 1/2 U
   //Now start ISR interrupt
   // Timer0 is already used for millis() - we'll just interrupt somewhere
   // in the middle and call the "Compare A" function below
   OCR0A = 0xAF;
   TIMSK0 |= _BV(OCIE0A);
   // ToDo is there a default timer in microseconds to ?
   // Interrupt is called once a millisecond
   // I assume now doppler rotate frequency 4 mSec or 1/.004 = 250 Hz //Measured 244 Hz at refpa3bnx pin
//Main Loop
void loop() {
  // ToDo
  // GetCapValues
  // Set the ant1,2,3,4 and refpa3bnx  pins ISR
  // Squelch status
  // OverFlow Reset the 4 kwadrant capicitors
  // Calibrate routine (add an degrees offset)
  // SinCosDetector
  // Send (averaged) and calibrated degrees out through the serialport
  // Receive remote serial cmd's like CW/CCW and Degrees
   //Integer
   byte swap = antPin[1]; //90 degrees
   int t;
   bNoSetKpins = true;
   GetCapValues();
   SetKpinsHigh();
   sqlstatus = Squelch();      //Squelch status check
  if (sqlstatus == cSqloverflow || (t > cMaxTime))
    t = 0;
    bNoSetKpins = true;
    EmptyCaps();
    bNoSetKpins= false;
    SetKpinsHigh();
 else
  //Relaxed sending degrees to serialport
 if (sqlstatus == cSqlopen2closed && bMultiPathAverage == false)
   if (MultiPathDetectSCF == false){
    Serial.println(Format3Degrees(Cali(Average(SinCosDetector()))));
//Try to read Calibration, CW/CCW, Timing Parameters
//000<cr> <lf> from MyMapping.exe as calibrate cmd
serialEvent;                     //Call SerialEvent once in a while
if (bStringComplete == true){
//Swap 90 and 270 degrees pins
 if (inputString == "CCW"){
   if (swap != antPin[1])
   swap=antPin[1];
   antPin[1]=antPin[3];
   antPin[3]=swap;
  else if (inputString == "CW")
   swap=antPin[1];
   antPin[3]=swap;
 else
  Calibrate = inputString.toInt();
  //Always Clear inputString Now
  inputString="";
//Do always every  loop
delay(cMainLoopDelay);       //Wait 500 mSec for next try ? fast enough I think
t += 1;                      //Total loops to compared against cMaxTime
//End of sketch
« Last Edit: May 01, 2015, 07:49:48 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #142 on: April 20, 2015, 05:48:02 pm »
Hello EveryBody,
I got from PE1KQP some very nice links
with documentry about radio WO2 and Radar
Have fun watching
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #143 on: April 29, 2015, 05:15:58 pm »
Hello Every Body,
I got the Arduino mounted on a board with the PCB hole Shield
for a doppler am plate RDF (max232).
So now I can focus on the arduino sketch
Take a loo here PA8W made also a nice Arduino Doppler with 128 by 64 pixel screen.
https://www.youtube.com/watch?v=rzyIFLcg6-A&feature=youtu.be
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #144 on: May 12, 2015, 07:10:19 pm »
Hello Every Body,
I worked again on the Arduino Sketch
It works.
I want to make 500 and 3000 Hz doppler rotation adjustments in it
with ISR timer interrupt
So I could send LOW or HIGH through serial USB/COM
and switch teh doppler rotation frequency.
(500Hz for nbfm and 3000Hz for wbfm)
Any hints how to do that
  ((C))PA3BNX
  Arduino Uno REV 3 Sketch
  Look at http://www.pi4wag.nl/projecten/doppler-peiler-radio-direction-finder
  For this there is a special Arduino Com/USB input in program MyMapping to show the Agrelo(%bbb<cr><lf>) headings on maps
  No adjustments on the arduino shield it self
  All adjustmenst like Calibrate-offset and CW/CCW through Serial Port
  Doppler frequency 500 - 3000 Hz ToDo
  Squelch level adjust ? ToDo
  Antenna test 1,2,3,4 Wait 3 seconds then restart scanning ?  ToDo
  Remote CMD's  ANT1 ANT2 ANT3 ANT4 CW CCW LOW HIGH (bbb Calibrate)
  @12-04-2015
  @13-04-2015
  @15-04-2015
  @17-04-2015
  @22-04-2015
  @24-04-2015
  @25-04-2015
  @26-04-2015
  @27-04-2015
  @29-04-2015
  @01-05-2015
  @02-05-2015
  @03-05-2015
  @05-05-2015
  @06-05-2015
  @08-05-2015
  @10-05-2015
  @12-05-2015
  Not quite ready yet but working!
  I want LOW and HIGH working Doppler ISR rotate Routines 500 Hz and 3000Hz(Now it runs only on 244 Hz)
  Explaining Arduino pins:
  antPins[4] Connect to antenna switcher pins
  kPins[4] Connect to kwadrant C's 4u7
  max232Pin[2] for Am WhatsonWatt DF through max232 external chip + and - 12 V
//Byte= 0>255
//Int=  -32768>32767
 String inputString="";             //Received serial string
 //Boolean
 boolean bStringComplete=false;     //Complete '\n' rxed serial string
 boolean bNoSetKpins=false;         //Do not change kPin[] because I am reading/empty them now
 boolean bNoAntScan=false;          //Do not change antPins while testing one antenna
 boolean bMultiPathAverage=false;   //Multipath heading found in received headings from Averaged
//Const Integer
//So I started with pin nbr 2
byte antPin[4]={2,3,4,5};           //Set antenna control pins (Not const because it can be CCW/CW)
const byte max232Pin[2]={7,8};      //Set Max232Pin vor AM plate antenna
const byte refpa3bnx=6;             //Pin for Referency frequency output to soundcard
const byte cHigh=9;                 //All kPins High Only Used in function SetKpins
const byte kPin[5]={9,10,11,12};    //4 pins caps 4u7
const byte kPinAnalog=0;            //A0 read voltage across one 4u7 cap pin A0 to A5
const int cOffset=511;              // .5 * 1023 caps offset
//Squelch Signals
const byte cSqlclosed=0;
const byte cSqlclosed2open=1;
const byte cSqlopen2closed=2;
const byte cSqloverflow=3;          //Capicitors are full
const int cNodegrees=999;           //Squelch No Signal or cSqlopen2closed Clear avDegrees and set avDegrees to cNodegrees
const int cReset=888;               //Clear Average and avDegrees
const int cMaxTime=60;              //15 Sec/cMainLoopDelay Max time 60 * 250 = 15 Sec
const int cMainLoopDelay=1000;      //How fast the main loop runs in mSec
const int cMinAudioAmplitude=60;    //There is enough signal to SinCosDetect
const int cMaxSymmetric=175;        //Max Sym in MultiPathSCF
//Float const
const float rad1=180/PI;            //57.295827
//Integer
byte sqlstatus=cSqlclosed;
byte swap=antPin[1];                //90 degrees Loop
int Cap[4]={0,0,0,0};
int Calibrate=0;                    //Calibrate degrees default
int tMaxTime=0;                   //Used in Loop
 static byte c;
 if (c==4){
  c=0;
 if (bNoAntScan == false)
 SetAntPins(c);
 SetKpins(c);
 SetMax232Pins(c);
//Always increment
c++;
//Listen/Test on each antenna separate for about 3 sec's
void AntTest(byte a){
 bNoAntScan = true;
 //Switch all Low
 for (byte i=0;i<4;i++)
 //Switch one High
 digitalWrite(antPin[a],HIGH);
 SetMax232Pins(a);
 delay(3000);
 //Switch again to Low
 digitalWrite(antPin[a],LOW);
 bNoAntScan = false;
 a+=1;
 Serial.print(F("Ant test ")); //F means keep Ant test in ROM
 Serial.println(a);
//Max232Pins for AM Wattson Watt RDF
  switch (t){
  case 0:
   break;
  case 1:
   break;
  case 2:
   break;
  case 3:
   break;
 switch (t){
  case 0:
  break;
 case 1:
  break;
 case 2:
  break;
 case 3:
  break;
//Set kwadrant Cap Pins according to antPins
void SetKpins(byte t){
  //Nothing Todo now
  if (bNoSetKpins==true){return;}
  //Set all HIGH
  //Set the pin LOW to charge the cap
  //Only if t not cHigh
   if (t != cHigh) {
    digitalWrite(kPin[t],LOW);
  //This leaves all kPin[] HIGH when finished
  //Set all kwadrant Cap Pins HIGH
  //Read these one by one
  //delayMicroseconds(100);
  Cap[i]=analogRead(kPinAnalog)-cOffset;
  delayMicroseconds(150); //Ref say about .1 milli Sec to settel analogue
//This function leaves all kPin[] = HIGH
void EmptyCaps(){
 Serial.println(F("EmptyCaps"));
 byte i;
  for (i=0;i<4;i++)
 delay(1000);
 for (i=0;i<4;i++)
int Squelch(){
 int x;
 int z;
 for(byte i=0;i<4;i++)
   z=abs(Cap[i]);
   if (z>0);
   x=z;
 if (x>=cOffset)
 else if (x>=cMinAudioAmplitude)
 else if (sqlstatus==cSqlclosed2open && x<cMinAudioAmplitude)
  return cSqlopen2closed;
 else
  return cSqlclosed;
int x;
for (int i=0;i<4;i++){
  x+=Cap[i];
if (abs(x)>cMaxSymmetric){
return true;
else
return false;
//Calibrate
int Cali(int d){
 return LimitDegrees360(Calibrate+d);
String Format3Degrees(int d){
  String str;
  int digits[3];
  int reminder;
  digits[0]=d/100;
  reminder=d%100;
  digits[1]=reminder/10;
  reminder=reminder%10;
  digits[2]=reminder;
  str+='%';
  str+=digits[0];
  str+=digits[1];
  str+=digits[2];
  return str;
  //If 999 then return 999
  if (d==cNodegrees)
  return cNodegrees;
  else
   int x;
   x = d % 360;
   if (x<0)
   x += 360;
   return x;
//Average
int Average(int d){
  //If d = 999 (cNoDegrees) then reset average and return last avDegrees
  //If d = 888 (cReset) then Reset all and put last avDegrees back in arrays
  //Always return avDegrees and Set bMultiPath
  //Integer
  static int sum[4]={0,0,0,0};        //Sum of counts for each kwadrant
  static int c[4]={0,0,0,0};          //Cap tension/voltage in each kwadrant
  static int avDegrees=cNodegrees;    //Averaged degrees
  int xx[4]={0,0,0,0};                //Adjacent kwadrants counts
  int z=0;                            //Most adjacent headings
  int z1=0;                           //Other two kwandants headings Multipath
  int y=0;                            //Index where the most headings are
  //Reset/clear and return cNodegrees or last avDegrees
 switch (d){
 case cNodegrees:
  //Reset and Clear
   sum[i]=0;
   c[i]=0;
  avDegrees = cNodegrees;
  return avDegrees;
 case cReset: //Reset and fill with avDegrees
   //Reset
   sum[i]=0;
   c[i]=0;
   //Fill with last avDegrees
   d=avDegrees;
  if (d>=0 && d<90){
  sum[0]+=d;
  c[0]++;
  if (d>=90 && d<180){
   sum[1]+=d;
   c[1]++;
  if (d>=180 && d<270){
  sum[2]+=d;
  c[2]++;
  if (d>=270 && d<=360){
  sum[3]+=d;
  c[3]++;
 //No degrees found
  if (c[0]+c[1]+c[2]+c[3] == 0)
    return avDegrees;
  xx[0]=c[0]+c[1];
  xx[1]=c[1]+c[2];
  xx[2]=c[2]+c[3];
  xx[3]=c[3]+c[0];
  for (byte i=0;i<4;i++){
    if (xx[i]>=z){
    z=xx[i]; //Most Headings
    y=i;     //Witch 2 adjacent Array Index
//Check for multipath kwadrants
switch(z){
case 0:
 z1=2;
 break;
case 1:
 z1=3;
 break;
case 2:
 z1=0;
 break;
case 3:
 z1=1;
 break;
if (xx[z]>xx[z1]){
else
bMultiPathAverage=true;
switch(y){
case  0:
 avDegrees=(sum[0]+sum[1])/c[y];
 break;
case 1:
 avDegrees=(sum[1]+sum[2])/c[y];
 break;
case 2:
 avDegrees=(sum[2]+sum[3])/c[y];
 break;
case 3:
 if (c[3]==0 && c[0]>0){
 avDegrees=sum[0]/c[0];
 break;
 if (c[3]>0 && c[0]==0){
 avDegrees=sum[3]/c[3];
 break;
 if (c[3]>0 && c[0]>0){
 avDegrees=LimitDegrees360(((sum[3]/c[3])+((sum[0]/c[0])+360)/2));
 break;
  return avDegrees;
  int SinSum;
  int CosSum;
 //Serial.println(Cap[0]);
 //Serial.println(Cap[1]);
 //Serial.println(Cap[2]);
 //Serial.println(Cap[3]);
  SinSum=Cap[0]-Cap[2];
  CosSum=Cap[1]-Cap[3];
  if (SinSum==0 && CosSum==0){
  return cNodegrees;//No Signal
  else
  //Serial.println(atan2(SinSum,CosSum)*rad1); //Added 90 degrees so it's the same as zerocrossdetection
  return LimitDegrees360((atan2(SinSum,CosSum)*rad1)+90);
    //get the new byte:
    char inChar=(char)Serial.read();
    if (inChar=='z'||inChar=='\r'||inChar=='\n'||inputString.length() > 4 ){
      bStringComplete=true;
     else
      //add it to the inputString:
      inputString+=inChar;
boolean CheckOnlyNbr(String str){
//Check for only numbers 0 to 9 in the string
//48=0 57=9
 for (unsigned j=0;j<str.length();j++){
   byte x=str.charAt(j);
   if ((x<48)||(x>57) )
   return false;
 return true;
//SetUp
void setup()
   //Serial.println(Format3Degrees(cNodegrees));   //Squelch always closed at start
     pinMode(antPin[i],OUTPUT);
     pinMode(kPin[i] ,OUTPUT);
     digitalWrite(antPin[i],LOW);                  //antPin LOW = OFF
   // Now start ISR interrupt
   OCR0A=0xAF;
   TIMSK0|=_BV(OCIE0A);
//Main Loop
void loop() {
  // ToDo
  // GetCapValues
  // Squelch status
  // SinCosDetector
   bNoSetKpins=true;
   GetCapValues(); //Fill Values in Cap[] //Leaves all Kpins HIGH when finished
   bNoSetKpins=false;
   sqlstatus=Squelch();      //Squelch status check uses Cap[] values
   if (sqlstatus==cSqlclosed)
    tMaxTime=0;
    Average(cNodegrees); //Clear all
   else
    tMaxTime+=1;             //Total loops to compared against cMaxTime
  if (sqlstatus==cSqloverflow||(tMaxTime>=cMaxTime))
    bNoSetKpins=true;
    EmptyCaps();//Leaves all Kpins HIGH
    bNoSetKpins=false;
 else
   //Not Ready here but working
   boolean bSCF;
   byte x1;
   byte x2;
   //bSCF=MultiPathDetectSCF();
   x1=SinCosDetector();
   //Never add a MultiPath SCF value to Average
   if (bSCF==false)
   x2=Average(x1);
   if (sqlstatus==cSqlopen2closed)
   if (bMultiPathAverage==false)
   Serial.println(Format3Degrees(Cali(x2)));
   //Always Squelch Closed and Reset Average
   Serial.println(Format3Degrees(cNodegrees)); //Squelch Closed
  else if (sqlstatus==cSqlclosed2open)
serialEvent();          //Call SerialEvent once in a while
if (bStringComplete==true){
 if (inputString=="CW")
     Serial.println(inputString);
     if (swap!=antPin[1])
   swap=antPin[1];
   antPin[3]=swap;
  else if (inputString=="CCW")
    if (swap!=antPin[3])
   swap=antPin[3];
   antPin[3]=antPin[1];
   antPin[1]=swap;
  else if (inputString=="ANT1")
  AntTest(0);
  else if (inputString=="ANT2")
  AntTest(1);
  else if (inputString=="ANT3")
  AntTest(2);
  else if (inputString=="ANT4")
  AntTest(3);
  else if (inputString=="LOW")
  //ToDo ISR 500 Hz
  else if (inputString=="HIGH")
  //ToDo ISR 3000 Hz
  else
  //Try Calibrate offset
  if (CheckOnlyNbr(inputString)==true)
    int x;
    x=inputString.toInt();
    if (x>=0 && x <=360)
    Calibrate=x;
    Serial.print(F("Calibrate="));
    Serial.println(Calibrate);
   //Now clear inputString because all done
   inputString="";
//Reset
if(tMaxTime>=cMaxTime)
 tMaxTime=0;
 Average(cReset); //Clear and Reset avDegrees
//Wait 250 a 1000 mSec for next try ? fast enough I think
} //End of sketch Last bracket of Loop
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #145 on: May 18, 2015, 05:31:24 pm »
Hello Every body.
What type op doppler antenna give best results indoor
on the loft ?
I think the groundplate 4 monopole antenna array because it looks a bit upwards
so not so much near by vincinity groundreflections.
See picture hi..
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #146 on: May 23, 2015, 06:26:02 pm »
Hello Every Body,
I did fix some issues with the SuperSimpleArduinoDoppler
I use now for the doppler rotation timing timer2
It does run now on 500 700 or 900Hz.
Today 30-may-2015
Today 03-june-2015 Again update
Now with a flutter count.
I updated the arduino doppler software
It now uses the EEPROM.write and read to store
Doppler frequency, CW/CCW and Calibration offset
I also changed the 1k series resistor in the arduino doppler shield after the decoupling C 4u7 into 100R
So my scanner RX doesn't has to be so loud hi..
Work in progress  :-+
Try it
« Last Edit: June 03, 2015, 05:25:10 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #147 on: May 30, 2015, 06:47:14 pm »
Hello every body
I saw this You Tube
HN199 SWR  AE4QL Bill Hays
Recommended view for every radio ham  :-+
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #148 on: June 28, 2015, 06:59:56 pm »
Hello Every Body,
I did add a speaker to my arduino SuperSimpleArduinoDoppler
And I fixed again a bug in the Arduino Code.
There also is a new Mymapping  file on our PI4WAG site 1.55
It has fixed averaging in the arduino terminal etc...
Today 01-july 2015 update Arduino3.txt
Some bugs fixed.
« Last Edit: July 01, 2015, 05:49:04 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #149 on: June 30, 2015, 01:30:10 pm »
Hello Every Body,
Nice doppler You Tube
Greetings,
Lodewijk
Credo:
Home brew projects:
