If the reset circuit is controlled by a threshold of CPU Voltage Supply:
Then the Supply of CPU may still not be stable and within CPU spec at the time when Reset Pulse is over.
If you are ramping Input to CPU supply Circuit very slowly.
Could try a Reset circuit with higher threshold and/or longer reset pulse.
Or a CPU supply circuit with power good output, best if open drain, pull up resistor to CPU supply, connected to power good and reset supervisor input in parallel
