Author Topic: Recommendations for a High Quality +/- 15V Power Supply  (Read 4844 times)
Offline cpsmusicTopic starter
« on: November 13, 2019, 04:44:09 am »
I'm a musician and have a small home studio. I'd like to build a high quality +/- 15V power supply to power a W492EQ. More details of the project can be found here:https://groupdiy.com/index.php?topic=28332.0
I have beginner-to-intermediate level electronics knowledge and have been researching power supplies. Problem is, the more I read, the more I'm confused about what I need. I don't want to go down the "audiophile path" and include things that aren't necessary. However, as this is a one-off project I don't mind going the extra mile in terms of quality. i'm hoping to get either a PCB or a kit.
Just wondering what people would recommend for this project?
Cheers,
Chris
Offline Hiemal
Re: Recommendations for a High Quality +/- 15V Power Supply
« Reply #1 on: November 13, 2019, 06:45:36 am »
Well, you have a few different options.
The easiest, and simplest method would just to use a center tapped transformer, and two linear regulators to give you your plus and minus rails. Add some decent filter capacitance, and you have a pretty foolproof bipolar supply. Of course, this requires mains.
If your project is battery powered, then you could try a charge pump; keep in mind though most charge pumps are relatively limited in their output power capability, typically in the range of 20 mA. It's also hard to find a high voltage charge pump that can handle 15 volts, so this might be disqualified based off of that alone.
Then there's the DC-DC converters; an inverting buck/boost converter could give you your negative rail, and a normal boost converter gives you your +15 rail. Biggest downside to these is noise, and they also typically require a minimum load to prevent oscillations.
There's also AC-DC switch mode power supplies, which could also give you your plus and minus rails.
All of these options you can buy off the shelf solutions for. Meanwell makes good AC-DC converters.
As to what is "best", well.... Eeeh. I'd lean towards just a transformer since it's pretty foolproof and is probably going to be the cheapest solution too. This is my opinion though, and I'm sure there will be people who disagree.
The following users thanked this post: cpsmusic
Offline MarkF
« Reply #2 on: November 13, 2019, 01:51:46 pm »
In case you need the simple linear regulator design (+/-15V @ 1A):
Click for larger picture.
871402-0
And a PCB layout I did for power supplies I built:
871406-1
« Last Edit: November 14, 2019, 04:15:40 am by MarkF »
Offline AG6QR
    • AG6QR Blog
« Reply #3 on: November 13, 2019, 02:47:13 pm »
Check out the Elenco XP-720, available as a kit or preassembled.  The manual is online and includes detailed schematics and theory of operation.  This is a classic linear power supply with a center-tapped transformer.  If it doesn't meet your needs, it might form a starting point for something that does.
It is only rated at one amp on each rail (there is also a 5V rail rated at 3A), and it is big and heavy compared to switching supplies.
Offline dom0
« Reply #4 on: November 13, 2019, 04:05:24 pm »
With 8 NE5532s the circuit shouldn't need more than ~200 mA. +-15 V @ 200 mA you can do with an AC wall-wart and dual one-way rectification.
