This is where you spend the time going through the data sheet. Page 4 says I_adj is typically 3uA, but a maximum of 10uA. Page 7 shows what it looks like as a function of temperature.
The value of R5 (4.1k) determines just how much effect I_adj has on your output voltage. With the typical 3uA, your output voltage increases by 12.3mV due to I_adj * R5. If I_adj were to go to 10uA, your output voltage would increase by 41mV. If you need a lower shift, reduce the value of resistor for R5.
