Hi all,
I have a project I am trying to put together, basically to sense when my AC unit turns on so I can turn on an extractor fan.
I decided to go with a current sensor on the AC line: when the compressor starts the sensor triggers a relay. The relay triggers a 24V relay which turns on the 220V extractor.
Both the sensor board and the relay are 24DC powered, from the same PSU.
The circuit worked a few times and then the LM358 op-amp blew up when I powered the board.
Checking with my scope I found that when the relay (the one triggering the 220V fan) is de-energised, the magnetic field collapsing causes a voltage spike up to 170V (326V p/p) which clearly the op-amp didn't like.
I added a diode at the relay coil and that lowered that spike to something more manageable of 60V (120V p/p) but I was wondering if I can do more to protect the op-amp?
One way would be to use a separate supply for the current sensor board but that would mean two power supplies which I'd like to avoid.
Any advice?
A basic sketch of the circuit is attached. Thank you!
