Author Topic: Request for IC driver suggestion for brushed DC motor  (Read 704 times)
Offline smd32Topic starter
  • Country: al
« on: March 21, 2023, 02:14:26 am »
I am in need of an IC driver for a brushed DC motor that should meet the following requirements:
Bidirectional control
PWM speed control
Presence of a heatsink pad
No cooling pad on the PCB but the option for attaching a heatsink
Continuous current greater than 2A
Voltage flexibility for motor selection (12V or 24V)
any suggestions for this IC
Not an L298
Thank you.
Offline H.O
Re: Request for IC driver suggestion for brushed DC motor
« Reply #1 on: March 21, 2023, 05:47:04 am »
L6203, LMD18200 and LB11651 are a couple that are available for thru-hole with heatsink tab. If you can go SMD with cooling via PCB you have dozens to choose from.
The following users thanked this post: smd32
