The most likely cause is the difference between measuring the ISOLATED resistor gives you its actual value.But when you put it into the circuit, the resistance from one end to the other is affected by the rest of the circuit.In general, "in-circuit" measurements of components are rarely the same as isolated measurements.Do you have the circuit diagram ("schematic") for your board?P.S: You can go back and delete the false-start messages. There should be a link in the upper right corner that says "Remove"
Oh I didn't think of that.... I'm still learning.
Quote from: TVman on May 20, 2014, 03:57:10 amOh I didn't think of that.... I'm still learning. Happens all the time in computer repair. Pain in the rear actually, because it means removing everything to find a problem, and if you've already removed it, it's just easier to replace it!
Quote from: Richard Crowley on May 20, 2014, 03:53:36 amThe most likely cause is the difference between measuring the ISOLATED resistor gives you its actual value.But when you put it into the circuit, the resistance from one end to the other is affected by the rest of the circuit.In general, "in-circuit" measurements of components are rarely the same as isolated measurements.Do you have the circuit diagram ("schematic") for your board?P.S: You can go back and delete the false-start messages. There should be a link in the upper right corner that says "Remove"Oh I didn't think of that.... I'm still learning.
