Author Topic: Reverse breakdown of BE junction: damaging current?  (Read 2829 times)
Offline dom0Topic starter
« on: July 22, 2015, 09:32:19 am »
So ... the reverse breakdown of the BE junction of BJTs is well-known. What doesn't seem to be well-known is how high the breakdown current must be to permanently degrade the part. I read some vague references like "Beta is permanently lowered at low reverse currents" and the like, but nothing solid. Does that mean µA? A few hundred nA? So, what's the maximum reasonable reverse ib for your average few-hundred mA ic, couple-dozen V Uces low power transistor like a 2N2222 or a BC337?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Reverse breakdown of BE junction: damaging current?
« Reply #1 on: July 22, 2015, 10:04:00 am »
Depends on the extent of damage.  I've never seen data on how fast the damage accumulates (presumably, it's a dosage measured linearly by charge), and to what currents it causes problems at (presumably, higher doses cause a higher current threshold effect?); you'd have to run trials yourself to see.
Also interesting to see, would be the effect on low frequency noise (0.1-1000Hz?).
Supposedly, it can also be partially annealed at soldering temperatures.
Maximum safe level?  Vebo is measured at 10uA, but beyond that, Idunno.  To what end?  If you want a good zener, get a real one; much less noise, and guaranteed voltage level.  If for repetitive conditions in an amplifier or switching circuit, use an antiparallel (E-B) protection diode (or a lower voltage bidirectional TVS, or a series prevention diode).
Seven Transistor Labs, LLC
« Reply #2 on: July 22, 2015, 10:22:56 am »
Thanks for the answer. It still does surprise me that no one ever collected this data, but then again countermeasures are usually simple or not needed at all by design.
Offline nqtronix
« Reply #3 on: July 22, 2015, 04:01:47 pm »
I've used the BE breakdown of the BC807/817 to protect the gate of (slow switching) mosfets a few times. They break down relative precisly at 8V, which is good enough for me. Considering a typical zener diode withstands several mA witout issues I decided to go up to 1mA BE reverse current. Till now it works fine. If you don't care about the accuracy of the breakdown voltage, b
and just need a relativly current independed voltage drop like the 0.7V pn diode drop then go for it, else get a zener diode.
Online edavid
« Reply #4 on: July 22, 2015, 04:41:09 pm »
Zero tolerance!
(I just don't see any reason why there would be a threshold.)
See also: https://www.eevblog.com/forum/projects/bjt-ce-breakdown-permanent-degradation/msg633836/#msg633836 and later posts in that thread
