I want to use a cheap 12V/20A LED power supply to power my 3D printer.
I suspect it has no protection for reverse current (back EMI from motors) as it is made for LEDs that will never force reverse current back into power supply.
I need a protection circuit that will stop the voltage/current that gets induced when someone moves the motors by hand quickly from destorying the power supply...
I was thinking about putting a 13V zener across the output but that looks a bit flimsy... biggest power zener I can find atm is 5W rated. Higher power zeners are ridiculously expensive...
Anyone got a good circuit that will
- short out at 13V thru something beefy that can take ~50W of power
- release once the voltage drops back to 12V so that the power supply is not shorted out
- will not oscillate (much)
