Author Topic: Reverse diode current problem  (Read 2479 times)
Offline Md Mubdiul HasanTopic starter
  • Lets learn more to be more inspired in Electronics
« on: November 20, 2017, 06:38:01 am »
Hello there,
Take a look the schematic, I have observed this circuit in maximum and minimum temperature, the problems are
The gate of Q3 will be turned on at maximum temperature, while MAIN_PWR_EN is 0(disable).
1. D7 shows reverse diode current.
2. Q10 is also malfunctioning.
According to datasheet, torexsemi.com/file/xbs053v13r/XBS053V13R.pdf, the reverse current at 20V reverse volatge is 100u A. We are expecting a unidirectional current path towards R41 and R68 junction. Somehow in this circuit, current is producing,,,, |O
The parameters from datasheet of Q3 (onsemi.com/pub/Collateral/NTR2101P-D.PDF) says, if you calculate the gate current,Ig = Qg/(td(on)+tr); (Total Gate Charge) / (Turn-on delay time + rise time of MOSFET) it will about 0.37 A. (at VGS = ?4.5 V, VDD = ?4.0 V, ID = ?1.2 A, RG = 6.0 ohm) Reverse leakage might be temperature dependent, if you can see the circuit, a voltage difference between VIN(4.2v) and V_3V3 if Q3 is turned on that could make reverse path for diode conduction.
« Last Edit: November 21, 2017, 02:46:24 am by Md Mubdiul Hasan »
Hasan
Offline danadak
Re: Reverse diode current problem
« Reply #1 on: November 20, 2017, 10:45:28 am »
Downsides of schottky diodes are precisely what you observe,
high reverse leakage.
You might look around for a better part, 100 uA does seem a tad high.
Regards, Dana.
The following users thanked this post: Md Mubdiul Hasan
Offline RobK_NL
« Reply #2 on: November 20, 2017, 07:23:05 pm »
I agree with Dana that that 100µA spec is pretty high. And that's at 25°C!
By comparison, the RB168LAM-30 (https://www.digikey.nl/product-detail/en/rohm-semiconductor/RB168LAM-30TR/RB168LAM-30CT-ND/7243343) is spec'd for 0.6µA max at 30V Vr.
Tell us what problem you want to solve, not what solution you're having problems with
« Reply #3 on: November 21, 2017, 04:10:19 am »
Do you mean downside diode D7?
Can you compare my calculated gate current in actual case?
Hasan
« Reply #4 on: November 21, 2017, 04:14:35 am »
My company wish to replace, http://www.mouser.com/ds/2/348/rb520s-30-209876.pdf and I wanna do heat chamber test  again.
Do you agree with this part?
Hasan
Offline danadak
« Reply #5 on: November 21, 2017, 11:49:32 am »
Yes on question D7, it is D7 being discussed.
Your Mouser replacement shows no high temp leakage performance.
You could contact vendor and ask for characterization data at high
temp.
I would sim this design to get at peak gate drive current. You could
use LTCspice, Tina TI spice, many vendors have simulators that would
handle this.
http://www.ti.com/lit/ml/slua618/slua618.pdf
https://www.semikron.com/dl/service-support/downloads/download/semikron-application-note-igbt-driver-calculation-en-2007-10-31-rev-00/
https://www.infineon.com/dgdl/an-944.pdf?fileId=5546d462533600a40153559eb9841190
Regards,. Dana.
« Reply #6 on: November 22, 2017, 01:40:17 am »
Thank you sir Danadak,
temp.
I will talk to them, but already the circuit is ready for production repair department.
I think, the suitable diode what RobK_NL has said is OK.
handle this.
Well said, I have been used those tool.
But, if you see the circuit we need to generate some shots of signal like MAIN_PWR_EN, PWR_HOLD, PWR_IND signal.
As this device is OS related firmware, we can just make signal conditioning  by the circuit.
Can you suggest which tool I need to apply here?
Any OR, AND, NOR, gate signal?
Hasan
