I am trying to reverse engineer a blood pressure cuff. One of the automatic units that self inflates then takes a reading.
http://www.cooking-hacks.com/blood-pressure-sensor-sphygmomanometer-v2-0]This unit to be exact[/url]
The system runs off a 6V battery pack with a selection of discrete components and a processor under a blob. The only connection to the pressure cuff aside from a pump and a pressure relief valve is a pressure sensor. Removing the sensor and searching the product number turns up nothing, considering the die under the blob production method I expect they are manufacturing these devices in a high enough quantity that they have possibly had a manufacturer produce a custom sensor for them. I dont know if this unit is simply an analogue device or if it has some kind of serial interface.
Frustratingly no combination of probing the six pins on this package produces a readout on me DS1052 that I can see as being a useful signal. None of the pins are connected to the cathode of the battery [only tone tested, will check higher resistances]. The only image I see on my scope is a stable ~2v signal on some combination of pins. I cannot see any digital traffic of any kind nor can i see an appreciable ammount of analogue data that would indicate a pure analogue output, any noise is barely above the scopes internal noise and I could not see it being anywhere near clear enough for detecting the minor pressure ticks of a systolic pulse.
Is there some other testing technique I am missing? The device still operates perfectly as I run my analysis (albeit on a bottle of water and not my arm). How else can I attach my probes and why would the device not be connected to ground?
Please help I am at a complete loss here
