I have done a ton of testing now that I can send RF commands. Now that I have (hopefully) all of the animations and effects, I am going to make a flipper app that can both emulate a beacon and a lantern.
The receiver plays 37 color palettes × 20 effect modes, plus 24 single-color modes in any RGB color, all chosen by two or four bytes of a 32-byte radio frame. Every animation is deterministic: each one repeats exactly or ends in a fixed state, so all of them can be rebuilt from the recordings.
Everything here was recovered by watching the receiver: a tester Pico sent frames, and a Feather RP2040 logged both the payload the receiver read from its radio and every frame it sent to the LEDs. No original source code or notes were used.
Frame format
The receiver only acts on byte 0, byte 4 (or bytes 4–6) and byte 7; the counter and trailer frame the message, and the rest is ignored as far as tests show.
Byte
Effect frame
Color frame
0
C0
BF
1–2
counter, big-endian, +1 about every 100 ms
same
3
F8 (ignored: 00, 60, 78, E0, F0 all work the same)
layout id: F8 (layout A and B)
4
palette (PP), 00–25
red
5
keep 00: other values make fade modes freeze or go dark, unpredictably
green
6
keep 00, same as byte 5
blue
7
effect mode (QQ), 00–13
color mode, 00–17
8–9
00 (the chase ignores them; keep 00)
B0 1F: byte 8 is ignored; byte 9 = 10–20 worked, while 00, 01, 08, 3F and FF made the receiver ignore the frame
10–30
00 (keep 00)
00, or the layout-B tail (ignored)
31
3F (= NOT byte 0)
40 (= NOT byte 0)
A new frame takes effect within about 20–60 ms. Other layout ids seen in the original capture (60, E0, 78, F0) are covered under Color frames.
Effect frames and palettes
Byte 4 picks one of 37 palettes (00–25, with 12 unused) and byte 7 picks how it animates; slots 26–FF are empty and turn the LEDs off.
• Solid (00–08): one color on all 10 LEDs.
• Color lists (0A–25): 2 or 3 colors. When static they repeat along LEDs 0–8; 2-color lists leave LED 8 dark. Color-cycling modes step through the list one color at a time.
• Fixed pattern (09): a one-entry palette whose entry is a whole 5-color pattern. Position modes (02, 06, 08, 13) show it like any pattern; color-stepping modes treat it as one color, so their loops run about 3× shorter than on a 3-color palette.
• LED 9 always copies LED 0, so patterns behave like 9 LEDs plus one duplicate.
PP
Type
Colors (RRGGBB)
00
solid
ffffff
01
solid
ff0000
02
solid
008000
03
solid
0000ff
04
solid
ffff00
05
solid
ff3800
06
solid
800080
07
solid
ff1030
08
solid
00ffff
09
fixed pattern
ff3030 · 80ff20 · 0000ff · 6408ff · ff2000
0A
2 colors
0000ff · 04b1ff
0B
3 colors
9000d0 · 80ff20 · ffc000
0C
2 colors
ff1030 · ff0000
0D
3 colors
ff1030 · ff0000 · d040c0
0E
3 colors
a0ff10 · ff8010 · ff6002
0F
3 colors
00ffff · 800280 · ff1040
10
3 colors
ff3800 · 00c0ff · ffff00
11
2 colors
800180 · 6001f0
12
empty (all off)
13
3 colors
20a040 · ffffff · 00ff1a
14
2 colors
05c6ad · 2aff00
15
2 colors
ff0230 · d040c0
16
2 colors
80ff20 · ffc000
17
3 colors
ff0000 · ffffff · 0000ff
18
2 colors
ff1030 · 00ffff
19
3 colors
ff0102 · ff0000 · ff0204
1A
2 colors
ff3800 · ff9600
1B
2 colors
612ac5 · ff4300
1C
3 colors
ff0000 · ff3800 · ffff00
1D
3 colors
ff0000 · ff3800 · 800080
1E
3 colors
ff3800 · ff0204 · 04ff04
1F
2 colors
ff1040 · ffffff
20
2 colors
0000ff · ffffff
21
3 colors
0000ff · ffffff · ffc000
22
3 colors
ff0000 · 04ff04 · ffffff
23
2 colors
ff0000 · 008000
24
2 colors
0000ff · c0c0c0
25
2 colors
ff0000 · ffe000
Effect modes (byte 7 of an effect frame)
QQ 00–13 are the 20 effect modes; 14–FF turn the LEDs off. Loop lengths below were measured on palette 0F (3 colors); modes marked cycles repeat once per color, so their loop is the per-color time × the number of colors.
QQ
Behavior
Loop on palette 0F
00
static pattern
01
blink, cycles: whole strip in color 1, off, color 2, off… (403 ms each step)
2.42 s (6 frames)
02
chase: one LED steps along every 84 ms, keeping its pattern color
755 ms (9 frames)
03
stepped pattern
503 ms (6 frames)
04
stepped pattern
839 ms (8 frames)
05
slow smooth fade
7.93 s
06
dots stepping every 164 ms
1.47 s (9 frames)
07
breathe, cycles: each color fades up and down (415 ms each)
1.25 s
08
same visible result as 06 on this palette
1.47 s (9 frames)
09
smooth fade
4.93 s
0A
steps mixed with fades
about 9.96 s (close, not exact, repeat)
0B
long fade sequence
17.0 s
0C
long fade sequence
15.3 s
0D
503 ms step rhythm with fading
5.43 s
0E
long fade sequence
10.8 s
0F
long fade sequence
11.8 s
10
sparkle-like single LEDs, but a fixed 95-step sequence
10.8 s
11
839 ms step rhythm with fading
13.2 s
12
sparkle-like single LEDs, a fixed 59-step sequence
7.77 s
13
candle: the static pattern flickering in brightness, 64 ms steps
2.04 s (32 frames)
Modes 02 and 13 measured the same on four other palettes (solid, 5-color, two 2-color). Only 02, 06, 08 and 13 work by LED position and keep the same loop on every palette; the other modes step through the palette's colors, so their loop scales with the number of colors (on palette 09, which counts as one entry: 01 = 806 ms, 05 = 2.64 s, 07 = 415 ms).
Color frames
Bytes 4–6 set any RGB color and byte 7 picks one of 24 color modes (00–17); 18–1F turn the LEDs off. This is a separate table from the effect modes. All measurements below used orange FF8000 on all 10 LEDs.
Byte 7
Behavior
Loop
00
static
01
candle flicker, 128 ms steps
4.09 s (32 frames)
02
smooth breathe
2.04 s
03
fast pulse
415 ms
04
on/off blink
407 ms
05
on/off blink
168 ms
06
fade
837 ms
07
pulse; the value in every captured layout-A frame
452 ms
08
fade
882 ms
09
fast flicker
175 ms (16 frames)
0A
stepped fade
503 ms (25 frames)
0B
stepped fade
283 ms (10 frames)
0C
on/off blink
119 ms
0D
on/off blink
84 ms
0E
single-LED chase, 164 ms steps
1.47 s
0F
single-LED chase, 84 ms steps
755 ms
10
fill / wipe, 164 ms steps
1.64 s
11
on/off blink
327 ms
12
single-LED chase
1.47 s
13
single-LED chase
755 ms
14
slow breathe
4.58 s
15
breathe
2.29 s
16
one-shot: candle flicker for about 4.6 s, then fades to off and stays off
17
one-shot: even fade from full to off over 4.1 s, then stays off
Layouts (byte 3):
• F8 layout A and B: both behave the same. Layout B adds a tail from byte 14 (BB …) that the receiver ignores.
• 60: a fixed preset; the color bytes are ignored and the LEDs show 000001 (almost off).
• E0, 78, F0: the receiver ignores them and stays on the idle candle, including all 13 real E0 frames from your remotes capture. They were rare there (1–5 each), so they may never have been meant for the light.
Idle candle and shared routines
When the receiver hears no valid frames it plays an orange candle: one color on all 10 LEDs, 32 brightness steps of 64 ms, repeating every 2.04 s. It goes idle 4.0 s after the last frame it hears.
How the receiver handles frames:
• Leaving idle waits for the candle cycle to finish, so a new frame can take up to 2 s to show. Between two active frames it switches within 20–60 ms.
• A different frame restarts its animation from the first step. Re-sending the same frame does not restart it.
• The counter does not need to change. A frozen counter kept the chase running for 19 s.
• Repeat every frame. The receiver hops between 3 channels and catches about 1 in 7 frames, so a single frame was never received. Keep sending at least every 4 s to stop it going idle.
The candle is one routine used in three places, all with the same 32-step brightness table:
Where
Color
Step time
Idle
orange (red about 3× green, no blue)
64 ms
Effect mode 13
the palette pattern
64 ms
Color mode 01
the frame's color
128 ms
The 32 steps use 24 distinct red levels (brightest first, not in playing order): f9 f7 f1 ec e7 e2 e0 dc da d8 d6 d4 d2 ce cb c7 c5 c3 c1 bb b5 a8 a6 9e. Color mode 16 runs the same flicker once before fading out.
Unused bytes and things ruled out
Only bytes 0, 4–7 and 31 carry meaning, but two other bytes must keep their usual values, and there is no second-color field.
What was tested
Result
Effect bytes 8, 9 and 12, each stepped 01–FF on the 0F chase (27 variations)
identical frames, colors and 755 ms loop every time
Effect bytes 9 and 12 on palette 25 blink (from the original capture)
no visible difference
Color frame: blue placed at every position from byte 10 to byte 30, in chase and candle modes (38 tests)
no blue, no change in color or timing
Layout-B tail (bytes 10–30) with color modes 00–1F
same results as layout A without the tail
Bytes that must keep their usual value:
• Effect bytes 5–6 = 00. Non-zero values left the chase unchanged but made fade modes (05, 07) freeze at one brightness or go dark. The same value gave different results on different runs.
• Color byte 9 = 1F. Values 10, 1E, 1F and 20 worked; 00, 01, 08, 3F and FF made the receiver ignore the frame and fall back to the idle candle (one run).
• Color byte 8 and effect byte 3 are ignored: any value works.
Two-color animations come only from the 2-color palettes in effect frames, not from a color you choose.
Still open:
• Whether palette 09 was meant as a single-pattern entry; it behaves consistently as one (tested in all 20 modes).
• Whether effect bytes 8–30 also upset the fade modes; they were only swept on the chase.
• What color byte 9 is checked against; only 10–20 hex have worked so far.
