I’ve seen a similar topic in here on the Fluke wiremap IDs, so I guess this is the best place to post this.
Mine is a similar story – I have several of the JDSU /Test-um/Blackbox Lanscaper/Lanroamer network testers, which come with an optional kit of 8 ID remotes.
They are good testers but sadly long discontinued and the remotes seldom come up for sale here, and are expensive when they do.
This is an example of the kit:
I’d like to try and make a set of remotes, but I only have #1 ID to go off.
I’ve sketched out the schematic, and included some pictures – there seems to be very little to it and I assume the ID is determined by the value of the resistors.
I’m unsure of the significance, if any, of the difference between the 5DY and 5DX diodes? – as far as I can see these are SOT-23 packages, but haven’t found much else on them.
I was thinking of trying to re-create the design in discrete components and see if it correctly registers the ID, and then swap different resistor values, or use some pots to figure out the missing IDs.
Obviously the ideal solution would be to find somebody who has a set who could check, but that seems unlikely.
I do know somebody with some, but they are not local and not that easy to open up, so I can’t really ask them to do that.
I don’t believe there is any easy way to determine the values externally.
I’d be grateful for any advice or tips.
