Author Topic: Reverse engineering modulated audio data  (Read 1932 times)
Offline holozipTopic starter
« on: December 31, 2013, 12:43:38 pm »
Hi folks,
I have an OSD unit onboard a model aircraft, which monitors battery life, speed, heading, altitude etc - and then overlays the results on top of a live video feed. It also modulates a data stream onto the audio channel, making the data available to accessories such as antenna trackers, or an iPhone app that plots the location on a map.
I'd like to reverse engineer the audio and use the data stream for use in my own projects, but I know very little about how to identify the encoding scheme.
Here is an example of the audio I found on youtube:
I've tried running the audio through the various modes available in sdr-radio without any success.
Can anyone help point me in the right direction?
Offline philpem
  • That Sneaky British Bloke
Re: Reverse engineering modulated audio data
« Reply #1 on: January 02, 2014, 02:35:55 am »
It's probably something simple like FSK or 2PSK, but you'd need an uncompressed sample of the audio to confirm that. Trying to work from the compressed audio in a Youtube video would be a fairly difficult feat...
Phil / M0OFX -- Electronics/Software Engineer
"Why do I have a room full of test gear? Why, it saves on the heating bill!"
