Author Topic: RFID frequency  (Read 3076 times)
Offline JaneTopic starter
RFID frequency
« on: July 23, 2015, 08:10:31 pm »
As far as I know, RFID can use a different frequencies. Is there any way how I can check what frequency my RFID uses ?
Thank you.
Offline Xenon Photon
  • Country: eg
Re: RFID frequency
« Reply #1 on: July 24, 2015, 05:14:27 am »
Spectrum analyzer on a powered device.
Btw, this is the general chat form!
Offline digsys
    • DIGSYS
Re: RFID frequency
« Reply #2 on: July 24, 2015, 05:19:38 am »
There are 3 main frequencies, which are usually standard, but some manufacturers do have a slight propritary version.
The type of tag can give it away - clothing, vehicle, animal. Plus if it is short / long range ie 10cm ... 4M
What is it used for? That's a starting point. More info needed.
Offline Halcyon
  • Global Moderator
Re: RFID frequency
« Reply #3 on: July 24, 2015, 06:17:29 am »
It should still be kept electronics/technology related for the most part. The OP's post is fine here.
Offline albert22
Re: RFID frequency
« Reply #4 on: July 24, 2015, 01:57:57 pm »
For the low frequencies ( 125 or 134 kHz ) I have used a small coil near the reader and checked the frequency on an oscilloscope. Probably the method will work for 13.56 MHz too.
Take into account that the reader will send  bursts and not a continuous waveform.
If you only have the tags and not the reader, it gets more complicated- Perhaps a Grid Dip meter could be used
https://en.wikipedia.org/wiki/Grid_dip_oscillator
Offline Mad ID
Re: RFID frequency
« Reply #5 on: July 24, 2015, 02:32:51 pm »
Or simply connect long ground lead which comes with probes to the tip and that loop is just fine to check the frequency.
