Author Topic: ring modulator  (Read 3434 times)
Offline RMmodTopic starter
ring modulator
« on: November 29, 2014, 11:45:38 pm »
Hello all,
I need help designing a ring modulator for AM(DSB) instead of DSB-SC..ANY help would be greatly appreciated!!
ROMI
Offline Howardlong
Re: ring modulator
« Reply #1 on: November 30, 2014, 12:16:29 am »
I apologise in advance if I am wrong, but if this is a homework question could you please give the entire question, because I don't quite understand what's being requested. If it's a real life question, please expand on the detail as to what you're trying to achieve.
Re: ring modulator
« Reply #2 on: November 30, 2014, 12:22:51 am »
THanks Howardlong!!
This is indeed a homework question and I really need to get this done on Multisim..Than I can demonstrate on breadboard though.
Ring modulators are used for DSB-SC generation as common practice but we are required to transmit AM (DSB) through modified ring modulator !!
Thanks again
Offline T3sl4co1l
    • Seven Transistor Labs
Re: ring modulator
« Reply #3 on: November 30, 2014, 01:04:14 am »
Ooh, LaTeX.  A professor who cares. :D
AM is done with a single or dual quadrant mixer, not a four quadrant mixer.  If you must use a ring modulator, you can add carrier back in... which seems pointless.  The whole reason to choose a DBM is because it affords some carrier rejection.
Preferably, you'd use a single balanced mixer (two diodes, or even better, a long tailed pair like this: http://www.classiccmp.org/rtellason/chipdata/ca3028.pdf ).
Seven Transistor Labs, LLC
Re: ring modulator
« Reply #4 on: November 30, 2014, 01:55:45 am »
can you draw it  please TIM :-X
Offline T3sl4co1l
Re: ring modulator
« Reply #5 on: November 30, 2014, 02:12:09 am »
Afraid that'd be doing your homework for you...
Read the textbook and note the difference between AM and DSB-SC.  Then read about adding voltages, or superposition, etc.
Re: ring modulator
« Reply #6 on: November 30, 2014, 02:23:36 am »
I understand your concern....
I have built something on Multisim but couldn't really move forward.....Please take a look at it..attached file for review
Thanks again.
