Author Topic: RM6203 - switching PSU controller  (Read 5896 times)
Offline ChupacabrasTopic starter
  • Country: sk
« on: February 15, 2016, 06:59:43 pm »
is there anybody experienced with switched power supply circuits/controllers?
I am looking into RM6203 datasheet. There is some typical application.
1. But I don't understand what is the reason for capacitor C10
2. Is it isolated topology?
Offline lukaq
  • Country: si
Re: RM6203 - switching PSU controller
« Reply #1 on: February 15, 2016, 07:12:30 pm »
1. is that Y cap or how it is called? must be for something else, since it is wired in wrong place
2. It is, you have transformer
« Last Edit: February 15, 2016, 07:14:53 pm by lukaq »
  • Country: sk
« Reply #2 on: February 15, 2016, 07:20:43 pm »
1. I do not think it s wired in wrong place. I found more circuits with cap wired like that.
2. There is transformer, but doesn't that cap bypass it? Couldn't it eventually pass some voltage to secondary?
Offline TonyBurroughs
« Reply #3 on: February 15, 2016, 07:44:35 pm »
Maybe that cap is for bypassing high frequency signals to ground so if there was noise on the incoming line it won't show up on the output.
That's a guess though.
Offline lukaq
  • Country: si
« Reply #4 on: February 15, 2016, 07:48:43 pm »
2. Well yes, but no: it is wired to high DC voltage, with almost only low freq. ripple of low amplitude and it is very likely a small value cap, so it won't pass much anything
Online Zero999
  • 0999
« Reply #5 on: February 15, 2016, 08:03:36 pm »
It's a Y capacitor.
Yes, it is in the correct place.
It ensures both sides of the DC-DC converter are shorted together at high frequencies.
Without the Y capacitor, high frequencies will be coupled from the switching transistor to the secondary side via the inter-winding capacitance of the transformer.
The downside a small current from the mains can leak across the Y capacitor to the secondary.
« Last Edit: February 16, 2016, 08:50:10 am by Hero999 »
