First, Happy Holidays to all!
I'm making a small wrist watch for my son using an ATTiny841 and keeping time with an M41T62 RTC from ST, all powered by a single lipo cell. I'm trying to keep the component count as low as possible, and I'm wondering if the accuracy of the RTC will be affected if I power it directly from the battery vs. through a small voltage regulator.
Powered from the battery, the voltage to the RTC will vary between 4.2v fully charged to ~3 volts. This is within the source voltage range of the RTC (1.3 to 4.4v). I just don't know if this will effect the RTCs accuracy vs. powering it through, say, a small 3.3v regulator so it always sees a steady voltage.
If I could save the space on the PCB of the regulator and caps, that would be great, but if it's going to throw off the accuracy, I'll fit them in.
Thanks in advance!
-Chris
