Loading [MathJax]/extensions/Safe.js
Author Topic: Stunningly consistent complementary differential amp circuitry  (Read 3670 times)
Offline FrankiTopic starter
I just found a really beautiful and consistent complementary differential amp circuit that I just wanted to share with everyone.
Usually I'm not into spamming people with unrelated circuits, but this one looks just gorrgeous *SteveIrvine*, just look at its delicate yet consistent current mirrors, even these are complementary! ;D
I have no idea whether this circuit actually works, but it would be a pain in the ass if it didn't. On the other hand, there is just one way to find out...
full size
http://www.freepatentsonline.com/6778014-0-large.jpg
here's the link, unfortunately, it's patented, but hopefully, there is a variant in the doc that is prior art:
http://www.freepatentsonline.com/6778014.html
I feel like I need to put that in a simulator somewhen just for the fun of seeing how it works.
« Last Edit: March 19, 2011, 11:37:52 pm by Franki »
Offline Zero999
  • 0999
Re: Stunningly consistent complementary differential amp circuitry
« Reply #1 on: March 20, 2011, 08:51:39 am »
The only way to prove it works, is to etch it onto silicon. It won't work when made from discrete components because they won't be matched.
I wonder they have an op-amp based on this design?
Offline scrat
« Reply #2 on: March 20, 2011, 10:00:43 pm »
I agree with Hero, and (although I'm not an integration designer) I think there are many differential stages like this on the ICs we use every day. BTW, I don't see what that inverter on the output stands for...
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
« Reply #3 on: March 24, 2011, 12:42:56 am »
strictly speaking, you are right, but for testing purposes, one may use a pot to cancel out manufactorung differences.
I haven's seen any in ICs.
There are a few power amps using complementary differential circuitries, but I haven't seen any using FETs or MOSFETs for that, they all use bipolar transistors and they only use it in some intermediate stages. Just like this one:
source by some unknown audio hobbyist:
http://www.littlefishbicycles.com/poweramp/
« Last Edit: March 24, 2011, 01:43:32 am by Franki »
Offline Zero999
  • 0999
« Reply #4 on: March 24, 2011, 07:52:44 pm »
The CA3160 was almost entirely CMOS.
http://www.intersil.com/data/fn/fn976.pdf
