Author Topic: Sawtooth Oscillator Waveform  (Read 2114 times)
Offline dotcom.comTopic starter
« on: May 05, 2023, 08:40:11 am »
I am currently working on a sawtooth oscillator and I cant seem to get the shape right. I'm not sure if it's a component issue. I am trying to use this to implement into a 10V boost converter.
EDIT:
I lowered my capacitance and R5 values and was able to generate a sawtooth. However I'm not sure how good it is especially at the start of it. I Attached the new screenshot of the transient and schematic below the original
« Last Edit: May 05, 2023, 08:58:51 pm by dotcom.com »
Offline Avelino Sampaio
  • Country: br
Re: Sawtooth Oscillator Waveform
« Reply #1 on: May 05, 2023, 09:53:28 am »
Watch the video of our participant W2aew
The following users thanked this post: Someone, chris_leyson, dotcom.com
Offline wasedadoc
« Reply #2 on: May 05, 2023, 02:30:21 pm »
Why do you want to use that to implement a boost converter?
Offline dobsonr741
« Reply #3 on: May 05, 2023, 03:59:18 pm »
The schematics is off. Follow the one on the youtube video. It uses a more precise current generator to have the linearity you wanted.
« Reply #4 on: May 05, 2023, 09:02:04 pm »
I am making this oscillator to meet certain design parameters of my boost converter. It is a part of my control scheme as I also have to create PWM, error amplifier and maybe a compensation network.
Where my parameters are:
a) Input voltage Vin=5V
b) Maximum load current = 250mA
c) Output voltage ripple < 50mV
d) LIR under 20%
e) Clock frequency=100KHz
f) Power efficiency >90%
Amplifier and switches must be implemented at transistor level.
Offline dobsonr741
Offline Someone
    • send complaints here
« Reply #6 on: May 05, 2023, 10:43:29 pm »
Seems this question has already been asked and responded on https://www.chegg.com/homework-help/questions-and-answers/b-justification-description-chosen-architecture-c-design-procedure-values-relevant-compone-q114095153
Certainly smelled like homework. Discrete transistor design, LIR, fixed frequency ? completely non-realistic.
Offline dobsonr741
« Reply #7 on: May 05, 2023, 11:59:08 pm »
Though I liked that it made me review the UJT oscillator, it's nice how the youtuber used a current source to linearize the sawtooth.
« Last Edit: May 06, 2023, 12:01:18 am by dobsonr741 »
Offline Doctorandus_P
« Reply #8 on: May 06, 2023, 07:54:37 pm »
Without even looking at the schematic (except for the 5V power supply rails):
The rising flank is fairly lineair up to about 4V, and then it starts to taper off. Conclusion is that your current source needs about 1V of headroom to work properly, and you should switch your switch before your capacitor is charged to 4V.
